Drivetrain Loss of performance without oil catch can?
Assuming oil coats the core of the IC without the use of a catch can, would a drop in IC performance be expected? If the answer is yes, I would also assume power output will suffer as well???
yup yup. I believe the coating of oil inside the IC insulates the colder Alum. from the hot air blowing thru it. Try putting a little oil on your finger, smear it around and blow on it. Then try it again without the oil.
Hope this helps
Hope this helps
Yes. It takes time for the i/c to get coated, which relates to driving habits and other intangibles. So, you will read anecdotal info where someone had a look at their intercooler at x miles and it was still clean, and someone else looked at their intercooler at x miles and it was oiled.
What is certain is that the i/c will be coated with oil over time, and the oil will interfere with the i/c's function, resulting in a higher temp intake charge, etc.
I'm sure I can figure a way to clean the inside of the IC after I install the catch can; sealing one end and filling half way with gasoline or acetone, shaking vigorously - the IC. However, do you have a suggestion? Tonyb recommended brakeclean for the outside which worked very well.
Damnit Jim, I'm a doctor, not a scientist!
If what you guys say is true, then why didnt they include an oil catch can with the standard engine?
In any case, I bought an M7 catch can today from Peter. I'm going to install it on Sunday while I'm waiting for my turn at the So. Cal. dyno gtg. Can't wait.
Originally Posted by ripley
oil will accululate in the IC regardless of what you do. The catch can will remove excess oil.
Originally Posted by onasled
I agree
, same experience here, but not as long a time
Kimolaoha
Jul 5, 2023 01:04 PM
Aug 21, 2015 12:59 PM
AoxoMoxoA
Aug 21, 2015 09:15 AM
M7Speed
Aug 6, 2015 01:48 PM
