Drivetrain 17% pulley - still low airmass?
Old May 21, 2024 | 04:45 AM
tb205gti's Avatar
tb205gti
Specs:
- 17% Alta pulley
- 400ml injectors
- JCW air box and filter, cold air from cowling and from the front (just like a regular JCW)
- Newman PH2 (250/400) cam
- BMW Throttle body
- Adrian remap
- 2.5" stainless exhaust - resonated
- Standard manifold + catalytic converter
- Upgraded intercooler
- AEM Wideband sensor pre-cat
- Shell VPower 100 petrol
So just had the cam and the 17% pulley fitted but I'm somewhat struggling with low airmass readings when I datalog.
A 3rd gear pull will only show 705kg/h just before 7.000 rpm. This should be ~200Bhp if my math is correct. This seems low for the mods I'm running, I'd expect ~810 kg/h. (boost is just under 16psi) Has anyone done some data logging with a newman cam and a 17% pulley?
I do have good AFR, from ~13 low down to 12ísh at the top. And the car pulls cleany - just not like I'd expect from the mods.
I'm running the original belt still - and the tensioner is almost fully extended, but I cannot hear or feel the belt slipping on it. The BPV is the original one with only vacum to the actuator, I plan on changing it to get the boost as well - to try and force it closed once it gets on boost.
Anything else i should investigate to find the reason for the low airmass ?
Old May 21, 2024 | 10:11 AM
megaDan's Avatar
megaDan
I have to believe you're slipping with the OEM size belt. That is wayyy too large for the application. We were fighting belt slip when troubleshooting a friend's car who was using a JCW belt (11%) with a 15% pulley.
Old May 21, 2024 | 12:16 PM
tb205gti's Avatar
tb205gti
That is also what I think, but I cannot hear it slipping, the power is very linear, no "bumps" or anything that would indicate a slipping belt. But you might be right.
I got a 1360mm otgether with the pulley, but that was massively shorter than the original, so looked "off". I have ordered a 1368mm one now theoretically that shouls be right for it.
Old May 21, 2024 | 06:42 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You 100% need to replace that belt with the correct shorter belt for the 17% pulley. When you use a belt that is too long it slips so small you don't hear it, but the MAP sensor will pick it up and it looks like spikes when you datalog the boost. That is what the ECU sees and pulls timing. This was one of the biggest problems we found when we started dyno tuning MINIs all the way back in 2007, such a simple fix, but people doing the tune didn't know how to read the data and would often think it was a fuel or clutch slip issue.
also note with those big intercoolers you will see a boost drop from the stock, so that can also effect you reading.
Old May 22, 2024 | 02:01 AM
tb205gti's Avatar
tb205gti
I did not see any spikes in the logs I did, but update frequency might be too slow for it to pick it up.
It doesn't pull timing according to my logs. I do run what I'd expect from the maps. (IIRC 26 deg at 6.500)
I have ordered a 1368mm belt for it, the 1360 was too short for my liking, so I'll try with the 1368mm. (Which should be spot on for a 17% reduces pulley)
Yes, drop in pressure, but increase in airflow It is the air flow that is low for my liking. I intentionally steered away from boost as this is not what makes power - air flow is
E_V_A_N
15
Aug 27, 2023 05:49 AM
moseichuk007
Sep 29, 2020 08:45 AM
dutch2081
Nov 28, 2012 05:20 AM
70spop
May 8, 2007 06:34 PM
nerd
Mar 19, 2005 09:53 AM
