Drivetrain billet compressor wheel
Old Feb 24, 2022 | 05:09 PM
mustang_gt_350's Avatar
mustang_gt_350
I have located a housing and billet compressor wheel kit on ebay. I was wondering if anyone has tried one? It says the back plate of the compressor housing needs machined to clearance the new larger wheel but that wouldn't be a issue for me to do. I'm sure the HP claims are exaggerated but i havn't really looked at the compressor sizes for the upgraded turbos available.
The listing claimsCustom made compressor housing and wheel for the Mini Cooper ko3 turbo.
I would also recommend out ko4 turbine shaft upgrade 44.4mm by 50mm
You ll need your compressor plate machined to fit this compressor wheel.
  • 50mm x 61 x 65mm 5+5 blade
  • Balanced Compressor Wheel
  • Good for 350 to 400hp
  • Compressor plate machining Required (easy task with lathe)
  • Turbine Housing Machining for ko4 turbine should be done also (we do offer this service as well as the shaft)
  • diverter valve can be recirculated, Please tell me in the messages at Check out if you need the diverter valve recirculated
  • Fits Mini Cooper ko3 turbo with Minor machining modification
Old Feb 24, 2022 | 05:43 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I’d say that unless you have experience in a machine shop and building turbos, skip it and buy a completed hybrid turbo for a reputable shop.
Old Feb 24, 2022 | 06:25 PM
mustang_gt_350
Machining isn't a issue. And Ive rebuild a few turbo's in the past.
I was mainly worried about it maybe being a little too laggy for street use.
Old Mar 4, 2022 | 02:40 PM
knt's Avatar
knt
Not too sure about the 350-400hp, as most hybrids have billet compressor wheel are only listed to ~300-350hp at a push for the MINI 1.6 engines.
Old Mar 4, 2022 | 02:43 PM
knt's Avatar
knt
A good hybrid turbo should be similar to the original turbo and not too laggy for street use.
Hvyjetdriver
Aug 6, 2018 09:24 PM
thebombardier
Jun 18, 2018 03:10 PM
orangecrush
Aug 6, 2008 03:13 AM
k_h_d
Tires, Wheels, & Brakes
Jul 4, 2008 09:05 PM
ejkd
Mar 23, 2007 09:10 PM
