Drivetrain electric water pump to block manifold fitting
Old Mar 10, 2021 | 07:47 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
anyone know of a off the shelf option that fits? I Need a straight inlet to clear the m62 supercharger intake for my davies craig water pump.
. small block chevy thermostat housing is very very close but just slightly too big to clear the block bracing around the inlet
Old Mar 10, 2021 | 01:29 PM
BlwnAway's Avatar
BlwnAway
Not off the shelf, but you could modify (weld) a piece of the correct pipe to a drilled (hole saw) out block off plate.
Old Mar 10, 2021 | 01:41 PM
MrBlah's Avatar
MrBlah
I may have found something that seems LS7's use at 3-in center hold the center hole setup
TheRealRandomAndrew
Apr 19, 2020 04:34 PM
mini-is-for-me
Mar 17, 2020 06:47 PM
missinmyjeep
Mar 28, 2017 10:35 AM
eliseo1981
Oct 10, 2016 12:53 PM
