Drivetrain Are these normal boost values or do I Have a leak?
Old Feb 20, 2021 | 07:24 AM
  #26
Juve's Avatar
Juve
Originally Posted by Eurothrasher
No your right, boost should probably continue to climb up to 6500 or 7000 depending on your tune setting.
And that low at idle I'm thinking maybe boost leak as that is a good way to gauge that....maybe cracked line for the FPR from right side of horn ? My last boost leak I found to be missing metal gasket at left side supercharger horn....
Who did your tune ?
Bytetronik has some experience with modded R53's, Bytetronik maybe he can chime in.
I'll Check the FPR lines!
AdrianCL tuned my car
Old Feb 20, 2021 | 01:51 PM
  #27
Hingis's Avatar
Hingis
Originally Posted by Juve
Hi guys, I´m sorry for digging up my own thread again.
But i´m yet to solve this problem!
Today I installed a detroit tuned BPV, I gained about 0.5 PSI across the rev range but unfortunatly the problem continues.
I get Peak Boost (13.4PSI) at 5600RPM and then the boost goes down to 12.3 and stays there till the rev limiter.
I dont know where to find the missing boost, with a 17% pulley i should be pushing 16 PSI.
Any ideas where to turn to next?
Already did belt, tensioner, BPV, IC Boots.
Any help is apreciated
As you can see after 5600RPM where I hit 13.5PSI the it drops to 12.4 and stays about there till the end
I still think your Newman cam might have something to do with this.. My catcam sees boost rising up to about 5k rpm or so and then kind of pegs there all the way to redline without further increasing, although power is still climbing. I just think its a bit of overlap hence our boost doesn't continue to build to redline like an engine with a stock cam.. Would be nice if other Newman cammed owners could chime in with their logs
Old Feb 20, 2021 | 05:34 PM
  #28
Juve's Avatar
Juve
Hey! Thanks for the reply!
That does make sense to me, but I think I should have a bit more boost with a 17% pulley and stock headers, don't you think?
Old Feb 20, 2021 | 07:43 PM
  #29
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
are those 3rd gear logs? I do not see full boost in 2nd.
this is a 3rd gear log on my track car, similar mods dominator cam, 17 %, 4:1 header, jcw airbox
https://datazap.me/u/mrblah/silver3r...16-17-18-19-22
Old Feb 20, 2021 | 08:02 PM
  #30
Juve's Avatar
Juve
It's second and then 3rd gear, the part highlighted in blue is already 3rd gear
Old Feb 20, 2021 | 11:46 PM
  #31
OCR's Avatar
OCR
Juve -
While I haven't read the whole thread, from what I gather, you installed a racier cam.
1. A cam with more duration than stock...WILL reduce pressure (boost), with no other changes.
2. A cam with more overlap than stock...WILL reduce pressure (boost), with no other changes.
3. Both one and two above, even more pressure reduction.
Mike
Old Feb 21, 2021 | 05:07 AM
  #32
Juve's Avatar
Juve
Originally Posted by OCR
Juve -
Mike
Hey Mike, thanks for the reply.
I understand that and I agree that a racier cam with more duration and overlap will cause a boost reduction.
But what about the fact that I hit peak boost at 5500rpm and then I lose about 1.5lbs of boost until the Rev limit instead of gaining?
Old Feb 21, 2021 | 11:47 AM
  #33
Hingis's Avatar
Hingis
Sorry I don't recall. Are you at sea level? Or at higher altitude
Old Feb 21, 2021 | 12:16 PM
  #34
Juve's Avatar
Juve
I am at sea level
Old Feb 21, 2021 | 12:27 PM
  #35
Hingis's Avatar
Hingis
I am at sea level
Presume you have checked the boots around your grs cooler for any signs of leakage. Have you tried putting your stock intercooler back on to see what boost numbers you get with that?
Old Feb 21, 2021 | 12:59 PM
  #36
Juve's Avatar
Juve
I did that today actually, same results unfortunately, only thing that i can remember that isnt new is the charge pipe with the green gasket, maybe its that?
Old Feb 21, 2021 | 01:01 PM
  #37
Juve's Avatar
Juve
Do you have any 2nd gear logs that you could send?
Old Feb 21, 2021 | 07:09 PM
  #38
MrBlah's Avatar
MrBlah
the link has a 2nd into 3rd log
I find 2nd gear logs useless for tuning, boost is lower
Old Feb 21, 2021 | 10:55 PM
  #39
OCR's Avatar
OCR
One thought is belt slippage.
Though I don't know why it would come back at or near the redline.
Next thought is the pop-off (don't know the Mini name for it !) valve letting the pressure drop. Possibly a vacuum leak, weak spring.
This I could understand acting odd, pressure vs. rpm.
Mike
Old Feb 22, 2021 | 05:48 AM
  #40
MrBlah's Avatar
MrBlah
can you do a better log in 3rd to redline? The one you posted is not usable IMO
Old Feb 22, 2021 | 06:00 AM
  #41
Juve's Avatar
Juve
I agree, will do a proper one later today and post it here.
Old Feb 22, 2021 | 01:55 PM
  #42
Juve's Avatar
Juve
Did this today but i was using a new logging program, still didn´t get the hang of it, but tomorrow ill do one with my old one.
Anyway here it is, 3rd, 3rd and 4th gear.
@MrBlah
https://datazap.me/u/ijuve/try?log=0&data=8-16-19
Seems Im getting max 13.9 PSI at 7k rpm in 4th gear.
P.S. Idk what happend on the 4th gear log but ignore the rev drop, when the boost hits 13.87PSI it was on the redline. I suggest enabling the speed chart to guide you
Old Feb 22, 2021 | 02:35 PM
  #43
MrBlah's Avatar
MrBlah
probably time to put a stock intercooler / boots on the car, you can also zip tie the bpv if you have not tried that
Old Feb 22, 2021 | 02:58 PM
  #44
Juve's Avatar
Juve
Boots are OEM and New, BPV is a New Detroit Tuned one installed this week, already swapped for the stock cooler yesterday https://datazap.me/u/ijuve/stock-ic?log=0&data=3-6-7 (2nd and 3rd gear), and got the same results.
I think it might just be the SC on its way out?
Old Feb 22, 2021 | 06:26 PM
  #45
MrBlah's Avatar
MrBlah
they are mechanical pumps, when they go out they start making terrible sounds.
could be pulley slip on the shaft, or belt slip but usually that shows up as boost dropping then coming back as it heats up and grabs again, how old is the tensioner and what size belt?
Old Feb 23, 2021 | 03:16 AM
  #46
Juve's Avatar
Juve
The tensioner and belt are 7Months old. About 5k kms. Both gates 6PK1360.
I kinda ruled out the belt/tensioner because i did these logs (https://datazap.me/u/ijuve/new-belt?log=0&data=3-7) the same day i installed them and the same happens
Old Feb 23, 2021 | 04:54 AM
  #47
MrBlah's Avatar
MrBlah
I cant find what the real length is on that belt, some it cross references to different lengths none of which look right for a 17 % pulley
try switching to a gates K060532, might need a helper to get it to fit, it will be very tight, a k060535 will fit easier but they slip for me like what you are seeing
Old Feb 23, 2021 | 05:01 AM
  #48
Juve's Avatar
Juve
The gates I have is 1360mm in length and 21,4 mm wide with 6 tracks
Old Feb 23, 2021 | 06:31 AM
  #49
MrBlah's Avatar
MrBlah
would slip on my car pretty sure that is a k060535
Old Feb 23, 2021 | 06:34 AM
  #50
MrBlah's Avatar
MrBlah
definitly is a 535 that's probably your problem that size slips bad on my car with 17%. That's not even a gates belt it's a "bando", you can look it up with the gates parts cross reference tool
https://ww2.gates.com/if/automotive/...ange/index.cfm
