Drivetrain Supersprint Exhaust Inside! . . .
Old Dec 7, 2004 | 07:46 AM
jason@promini's Avatar
jason@promini
I have had a lot of questions about the Supersprint exhaust lately, so here is what you wanted:
All Supersprint mufflers are of the flow through resonated design. This means each unit has no chambers or baffles to reduce velocity. Simply, a straight through in & out design that maintains the proper back pressure throughout the entire RPM range. The internal components are 100% stainless steel with a high heat resistant rock wool sound suppressing material, not found in any other systems. This is the reason we can offer you sound legal performance exhaust systems. Tubing is always mandrel bent for maximum flow. Flanges and hangers are O.E. or better quality for a perfect fit every time. Housings are all manufactured from 1.5mm material that is M.I.G. welded at all seams. The stainless systems are 100% 304 stainless.
The 63.5mm Y pipe replaces the factory 57mm Y pipe. As with all Supersprint components, plasma cut plate steel flanges and factory spec. metric fittings are utilized for easy installation.
The Supersprint header is designed for the ultimate scaveging effect. Equal length, mandrel bent and hand welded tubing mergest into 63.5mm collector tube (factory exit tube is 57mm) making for a strong and effective header.
Supersprint offers the largest tip style choices in the world!
If anyone has any other questions, they can call the office or reach me at j.walling@promini.com
Jason
Or
Or
Or
Thanks,
Jason
Old Jun 25, 2005 | 12:59 PM
chows4us's Avatar
chows4us
Questions on Supersprint
Whats the opinions on using Supersprint exhuasts vice Borla sports or others. Is the supersprint louder? I don't need to be sold on the quality because I'vd had supersprint on all my sports cars.
Do you really need this part of can you just use the straight part without the resonator (I'm assuming that is a resonator).
If that is true, cant you just use the straight pipe (w/resonator already there and just start at the y-pipe?
And, one last question (prolly a dumb one). how is the different size systems going to mate (i.e., from stock to 63mm)?
And one more, what parts of the JCW exhaust can I keep? Start at the Y-pipe?
Old Jun 26, 2005 | 06:43 PM
VoiD's Avatar
VoiD
Are supersprint headers illegal because they are missing a cat? will it throw any check engine light?
Old Jun 26, 2005 | 07:08 PM
ZAMIRZ's Avatar
ZAMIRZ
chows, you can use your factory center pipe and get the Y-pipe, mufflers and tip. This is how I have it on my car and it sounds fantastic. In my opinion, the tips are a complete rip off (something like $125.00), you can get very good quality tips for less than half that price if you just look around on the net, which is what I did. Overall, I'm super happy with the system. It's a little loud when you get in the boost, but has a very european sound. It's not fartcan honda like the Magnaflow and a little louder than the Borla.
Old Jun 26, 2005 | 07:14 PM
onasled's Avatar
onasled
I like this header and may get one for racing. Price is quite high for a catless header though. Was hoping the the OBX would come back to market.
Old Jun 26, 2005 | 08:22 PM
Morales's Avatar
Morales
One man's opinion.
I happen to like my Magnaflow very much, thank you. Not Honda fartcan at all.
Sorry to hijack the thread. Back to regularly scheduled programming.
Originally Posted by ZAMIRZ
It's not fartcan honda like the Magnaflow...
Old Jun 27, 2005 | 06:34 AM
VoiD's Avatar
VoiD
Supersprint also sells a straight center pipe without the resonator, but I was worried it might be too loud. With the resonator, it's slightly louder than stock. Should have gone with the straight pipe, as it's too quiet for me.
W0TM8
Dec 19, 2019 07:50 AM
AdrenaliNate
Nov 4, 2015 07:26 PM
shawnmc
Detailing 101
Sep 14, 2015 11:31 PM
ltjpunk7
Sep 6, 2015 07:32 AM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
