Drivetrain hp claims
Old Dec 6, 2004 | 11:37 AM
jlm's Avatar
jlm
hp claims
just for kicks, I have added up the hp claims from another webb site. Now I don't know if these are wheel hp claims or estimated crank hp claims, so here we go, and I'm going to assume wheel hp:
chip 7-10whp
pulley 16 hp
cam 5-8 hp
throttle body 5 hp
cat back ex 9 hp
header 7-9 hp
intake 5-7 hp
head 10-19 (trickier)
now we all know these aren't additive, right? nevertheless, they add up to 64-80 hp at the wheels.
A stock S will wheel at about 147 hp, so if you add it all up, you get 211.
my rig was dynoed at 212, the only extra bit was better tuning and larger injectors.
Old Dec 6, 2004 | 11:40 AM
El Diablito Rojo-N20Mini's Avatar
Originally Posted by jlm
just for kicks, I have added up the hp claims from another webb site. Now I don't know if these are wheel hp claims or estimated crank hp claims, so for kicks here we go, and I'm going to assume wheel hp:
chip 7-10whp
pulley 16 hp
cam 5-8 hp
throttle body 5 hp
cat back ex 9 hp
header 7-9 hp
intake 5-7 hp
my rig was 212, the only extra bit was better tuning and larger injectors.
one question.... what was YOUR MCS at the wheels before any mods?
that would be a good start to see if you had a normal S , weak or strong car to start with...
but in the end.... does it really matter?
dave's Avatar
dave
pug poo picker-upper
I believe those numbers are estimated whp with 12% adjustment for drivetrain loss.
Old Dec 6, 2004 | 11:58 AM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Sounds pretty close then, eh?
I'd like to know where some folks get their claims of 250+ horsepower packages with less than the above list. Not naming any names...
Randy
Old Dec 6, 2004 | 12:11 PM
SpiderX's Avatar
SpiderX
look what I started
Randy
This sounds like fallout from my erroneous thinking.
I WAS THINKING THAT SAME THING AS I WAS PURUSING THE SITES AT THE 250 HP CLAIMS.......HOW?
Old Dec 6, 2004 | 12:34 PM
Randy
it's quite simple really....
you fabricate them....
Old Dec 6, 2004 | 03:40 PM
jlm's Avatar
jlm
as I recall, over the last two years or so:
my rig has been on Helix' Mustang dyno many times. it was an early mule for testing several exhausts: stock 147whp (had an intake), Rogue, Supertrap, Helix...all on the same day. After putting on the head, One-click, 19%, header throttle body and cam, we got 179 at Helix.
Went up to Hubie at SPI, he measured 177 on his dynojet. He put on the Apex and tweaked it to 198 whp...couldn't break 200.
next week he put in 440 injectors and re-tweaked to get 212 and that was holding back a bit.
Old Dec 6, 2004 | 04:06 PM
my rig has been on Helix' Mustang dyno many times. it was an early mule for testing several exhausts: stock 147whp (had an intake), Rogue, Supertrap, Helix...all on the same day. After putting on the head, One-click, 19%, header throttle body and cam, we got 189 at Helix.
Went up to Hubie at SPI, he measured 187 on his dynojet. He put on the Apex and tweaked it to 198 whp...couldn't break 200.
he's good... no doubt about it
the Apex is worth 10-15whp like he said... it's a good bang for the buck
I have eliminated the stumble I got from the V39 software with the Apex
Old Dec 6, 2004 | 04:08 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Yeah, I think if anything, my numbers may be a bit low - as we know they aren't additive, yet they do add up pretty close on your car!
Here's what I have on my car engine wise, and I have tested it in every different way to get the most out of the parts on the market:
Alta intake
WMS throttle body
Hand ported intake piece from the TB to the supercharger
Alta supercharger pulley
WMS ported/polished intercooler runners
WMS Intercooler
Pilo coilpack
Nology plug wires
Denso IK22 sparkplugs
Big fuel injectors (if I remember right - 400cc)
WMS head/valves
Schrick cam
Alta crank pulley
Milltek header with race cat
Custom cat-back exhaust
Custom ECU programmed on the dyno
All of this netted 221 at the wheels - and it is quite a bit more in terms of cost and parts than most of the packages on the market. That's what it realistically takes to get those numbers though. That would be 251hp at the crank using a 12% driveline loss.
Cool thread
Randy
Old Dec 6, 2004 | 04:33 PM
ZAMIRZ's Avatar
ZAMIRZ
Do you have a wiring diagram for the S-AFC or S-AFC II? I've been waiting for a wiring diagram for a long-*** time and Hubie was supposed to help me out when they came out to SEMA last year, but he stopped responding to my emails and phone calls
Anyway, if you have the diagram I'd be very interested in taking a look. Or if Steve installs them, any idea how much he charges?
EDIT: BTW, what changes did you make to get rid of the stumble? Did you just lean it out a lot off-idle?
Old Dec 6, 2004 | 04:37 PM
Of course I have one.... but you have to be nice
You will have to ask steve on install
i leaned it out some in the stumble area... it was pig rich
I have NEVER had a problem with him returning phone calls or emails...
Old Dec 6, 2004 | 04:45 PM
ZAMIRZ's Avatar
ZAMIRZ
you have a PM
Old Dec 6, 2004 | 06:10 PM
SpiderX's Avatar
SpiderX
Since my car stumble I would like to know what an "Apex" is?
Old Dec 6, 2004 | 07:28 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
It is a fuel controller. The Unichip you have does the same thing with better resolution - we just have to tune it for your car on the dyno. You also have timing adjustability and a host of driver possibilities.
Hope that helps!
Randy
Old Dec 6, 2004 | 07:32 PM
it is a fuel adjustment controller in which the airflow sensor signal can be modified in a 12point RPM range by 1% increments to increase/decrease fuel in a range of +50% to -50%. It also has a knock meter which can help keep engine under optimum conditions.
also allows 2maps so when you want to use race gas you can already have it programed in for ease of use
Old Dec 7, 2004 | 04:11 AM
jlm's Avatar
jlm
it is also $340
Old Dec 7, 2004 | 04:45 AM
SpiderX's Avatar
SpiderX
it is also $340
OH!
Old Dec 7, 2004 | 09:41 AM
jlm's Avatar
jlm
more of the original report:
https://www.northamericanmotoring.co...ighlight=apexi
and :
http://www.mini2.com/forum/showthrea...ighlight=apexi
Old Dec 7, 2004 | 02:01 PM
larkie's Avatar
larkie
does biigger intercooler give any gains on the street? is it good to have with 15% pulley?
Old Dec 7, 2004 | 03:37 PM
miniaq's Avatar
miniaq
can anyone put a $ figure on the above mods?
Old Dec 7, 2004 | 03:55 PM
jlm's Avatar
jlm
you can find everything from several vendors except:
injectors and the apexi, with mandatory dyno tune: around $900
Old Dec 7, 2004 | 08:10 PM
I have been tuning my twincharge with the apex on the road with my wide-band PLX gauge and it is running much better. Still need to get on a dyno to really tweak it ..... I have to say it is one of the best mods I have (not counting the turbo) The car is such a joy to drive now even at lower RPMs. Throttle response has improved dramatically.
Old Dec 8, 2004 | 05:59 AM
62Lincoln's Avatar
62Lincoln
JLM, any comments on the a/f ratio on that dyno sheet? It looks like it stays above 12.0 up until about 5k rpm - is that considered okay for the MINI? I'm not implying anything good or bad, just not sure what is the accepted norm in the world of MINI tuning!
Old Dec 8, 2004 | 06:06 AM
14.6 is normal
12 is considered "safe" under heavy load
Old Dec 8, 2004 | 06:46 AM
jlm's Avatar
jlm
12.5 was our WOT target
