Drivetrain Clutch not disengaging
Old Jul 16, 2019 | 04:16 PM
Dopinoes's Avatar
Dopinoes
I just swapped my 5 speed midlands to a 6 speed getrag in my 2002 r50. I went with the valeo clutch and pressure plate. My problem is I can’t get the clutch to disengage. I replaced both the master and the slave because of this problem and no luck. I have pressure bled the system from both the reservoir and reverse pressure bled it from the slave bleed nipple multiple times. I have also vacuum bled it both directions and I have put pressure on the slave nipple and left it overnight trying to push the air up and out. I already pulled the tranny a second time to verify the disk direction and condition of pivot pin and throwout bearing guide all was fine. I’m at wits end here. I don’t live anywhere near a mini dealer or I would have already given up and taken it to them. What am I missing? I never find air in the system when I bleed it. Is there some issues I’m not aware of with the transmission swap I did?
Old Jul 16, 2019 | 05:54 PM
Dopinoes's Avatar
Dopinoes
How far out does
the piston on the slave go when the pedal is depressed? Mine goes out to 3 1/4” from the throwout bearing arm to the flange where slave bolts onto.
NathanMckee
Mar 23, 2018 06:06 AM
Pirate007
Aug 17, 2011 03:48 PM
Trickle X
Jul 21, 2010 07:42 AM
mhay
Dec 6, 2009 01:12 PM
Stewbie
Jan 15, 2007 06:57 AM
