Drivetrain F56 jb+
Old Sep 28, 2018 | 08:58 AM
#Dragon#'s Avatar
#Dragon#
F56 jb+
http://www.burgertuning.com/B48_B58_f_series_jb_quick_install_tuner.html
just out of interest how many of you guys have the jb+ for the f56 and do any of you run it past the 3 0clock factory setting.
Old Oct 2, 2018 | 06:26 PM
DavidPinAZ's Avatar
DavidPinAZ
I do and was, actually. 2019 MCS, JCW kit, not quite 500 miles on it. The JB+ came from the factory, unbeknownst to me, at one click below max. I installed it anyway. After a couple days, my mini gave me the “Drivetrain Malfunction: drive carefully” error. I checked the codes the next morning, and there was a P120308, which google helpfully identified as “boost pressure lower than expected”. I took the JB+ out, adjusted it to on click below 3 o'clock and my MCS has been happy ever since. The sports display with my current setup gets pegged at the 240HP marker, and my ODB reader show calculated HP at 126. Grain of salt and all that.
Old Oct 5, 2018 | 01:08 PM
J_L's Avatar
J_L
I'm confused about the HP readings off an OBD reader (or the OEM sports display, which is getting the same info I guess). How could it get accurate #s on a system like the Burger or NM, which is basically altering the sensor signals and tricking the ECU into adding more boost?
Old Oct 5, 2018 | 02:17 PM
MrGrumpy's Avatar
MrGrumpy
No clue.... I have wondered about these too. From my understanding, the tuner boxes basically trick the ECU into thinking it’s at a higher altitude to increase the demand for boost. I’ve been wondering if a boost gauge that reads off the MAP sensor like a lot of the plug in ones do, as well as dash command and the like, I’m curious if they still read accurately with these? Also what does tricking the ECU like that do to your AFR’s and timing? I do not have one, so my curiosity is purely academic, but I’d like to know. That’s why I leaned towards an ECU tune instead, plus I don’t have the warranty concerns that some have.
Old Oct 5, 2018 | 02:55 PM
#Dragon#'s Avatar
#Dragon#
Afr and timing are not affected as per burgermotorsport I am not sure on boost my afr reads perfect my boost gauge is the factory one that is connected to the canbus.
Old Oct 5, 2018 | 04:06 PM
DavidPinAZ's Avatar
DavidPinAZ
I don't think boost readings would be accurate via ODB. However, that should be the only thing affected by JB+ and the like. With the added boost, the engine will do more, and that can be measured.
Old Oct 7, 2018 | 08:04 PM
#Dragon#'s Avatar
#Dragon#
Jb+
So is anyone out there running the j b+ past the 3 o'clock setting ?
Old Oct 24, 2018 | 02:32 PM
thehoffcart's Avatar
thehoffcart
I am, I have it maxed out and it runs great with no problems. I have to say for the little part that it is, it has made an amazing difference in my F56 s. Definitely has more pick up in the top end so the car kinda has a big turbo kind of feel to it. It really kicks in right around 3k RPM, and comfortably provides extra power to about 6200 rpm.
Old Oct 26, 2018 | 03:04 AM
#Dragon#'s Avatar
#Dragon#
Thanks for the reply I think it's time to turn it up😁
Old Sep 8, 2024 | 02:52 AM
ChrisHarris's Avatar
ChrisHarris
late response...but I installed it as is about a year ago, figuring I'd feel out whatever the default before I fiddled with.
Finally opened it up a couple months ago to see that it was at about the 3pm setting...so i cranked it to the max and put it back in. About 3-5 seconds after startup, what sounded like my engine's lifters started clanking so I immediately turned it the car off.
Took it out, then drove around for a while to make sure all was good. Put some octane booster in the tank, put the JB+ back in at max, same clanking. Tried to put it back to default, same clanking - I likely set it a hair too high but didn't wanna take anymore chances with it for a while.
Finally put it back in today set at half. Runs smooth. Somewhat compromised feel but I'd rather have the peace of mind...since I can't help but think that each failed attempt was doing a number on my engine, even if the clanking was only momentary each time.
HemiCooper0509
Jan 24, 2016 05:52 PM
Aug 26, 2015 02:11 PM
christomapher
Feb 2, 2013 06:09 AM
Karrock
Jul 31, 2012 06:56 AM
TerminalVelocity
May 9, 2012 02:06 PM
