Drivetrain JCW + Racechip + 2K miles = P12a4 :(
Old Jun 28, 2018 | 07:47 AM
Johnnycash's Avatar
Johnnycash
Hi guys,
So I have a JCW working fine with the racechip ultimate, for 2K miles, roughly.
I just saw a check engine light coming, after a stall I think (It's a manual).
The code is P12a4.
I feel the car is less powerful than before.
I thought I could remove it with my OBD wifi and iphone app (dashcommand and four stroke).
Turns out, I can't.
What do you think?
Do you know to what this code is linked?
Only solution = Dealer?
Any experience from someone with this code?
Thanks a lot.
Old Jun 28, 2018 | 09:01 AM
hadjiikong's Avatar
hadjiikong
I had that code before and was due to a fault pressure sensor. I believe it is fairly common on the F56. I would just remove the Racechip and if you still have a warranty Mini should replace it no issue.
Old Jun 28, 2018 | 09:58 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
For removing the code, I use OBD Fusion and my wifi dongle
TVPostSound's Avatar
TVPostSound
Reseat the Racechip connectors.
Old Jun 28, 2018 | 10:40 AM
Johnnycash's Avatar
Johnnycash
what does that mean?
disconnect / reconnect?
Old Jun 30, 2018 | 09:28 AM
Johnnycash's Avatar
Johnnycash
So today I’ve disconnected everything, started the car and no CEL on the dash. Checked with the V-link, the code is stored and I cannot clear it.
so I put back the racechip, again no CEL.
but...
I feel the car slower than before, longer to build boost.
I’ve measured with the OBD the boost pressure, I read 13PSI @WOT in 3rd gear.
I’m not sure but am I not supposed to be more in the 16-18PSI range?
any ideas / suggestions before I drop the car to the dealer?
thanks
Old Jun 30, 2018 | 12:04 PM
TVPostSound
Call or email RaceChip before spending $$ at the dealer.
See if you can get a parts shop like Autozone to clear your code for free.
I found out an old plugin hardware scanner seems to clear codes easier than phone apps.
nqr31467
Aug 14, 2017 06:17 AM
All3MiniS
R60/61 Cooper S Drivetrain
99
Sep 29, 2016 07:57 AM
kirkleverington
Apr 22, 2013 12:34 PM
007-Mini
Oct 17, 2012 06:17 AM
All3MiniS
Jun 16, 2012 07:50 PM
