Drivetrain secondary o2 sensor extension cable
before I hack up a cable, anyone know if there are extension cables available for the 2nd o2 sensor?
My cat moved back quite a bit due to the 4:1 header, I need almost 12" more cable
Perhaps an electrical engineer type will chime in but I am thinking that if you went with a little larger gauge wire and soldered the joint the resistance would not be increased outside the parameter range.
With a shorter cat, the 4-2-1's do not push the O2 bung back so far that you cannot use the stock cable.
I don't think anyone makes an extension jumper.
You'll have to either splice in some extra wire to yours (same gauge wire is fine) or create your own juniper from a male and female plug, w/ wire, from a parts car.
There are two choices. Extend the body side harness or the O2 sensor harness. I would choose the former as the splices would be protected from the elements behind the heat shield, and you only do it once.
11mcsaz
Jul 18, 2013 08:04 PM
Navigation & Audio Longer Iphone cable or extension?
k_h_d
Jul 2, 2012 07:11 AM
