Drivetrain Mini Mania Header ODB2 Compliant?
Old Oct 21, 2004 | 10:35 AM
stever's Avatar
stever
I am currently looking in getting a Mini Mania Header, But I live in Pennsylvania which has ODB2 Emmissions. I would like to know if anyone has experienced problems passing emmissions with this header. I would like to know before shelling out a ton of cash.
Old Oct 21, 2004 | 11:06 AM
dpayne1's Avatar
dpayne1
I have had the MiniMania header installed for about 15 months - It passed emissions testing without a problem in VA this past June.
Old Oct 21, 2004 | 12:30 PM
D1JL's Avatar
D1JL
The inspectors may not even look that close however you may have more of an issue wilh the MIL coming on. I have a MM header, good stuff. I would suggest buying the one without the cat and then have the orignal cat put back in.
Dave
Old Oct 21, 2004 | 12:41 PM
stever's Avatar
stever
ODB2 Testing.
The Problem that I have is Pennsylvania Is ODB2 Compliant. My friend is my mechanic and is very worried it will not pass.
Old Oct 21, 2004 | 12:42 PM
mlebeau's Avatar
mlebeau
dpayne, what Mini Mania components do you have? I'm looking at going through them for most of my mods (thinking Stage 2 -> Stage 3 route eventually), and I'm always looking for more reviews from people who have used their products.
Thanks.
-mike
Old Oct 21, 2004 | 12:50 PM
stever's Avatar
stever
I have not ordered from them yet. I have the ability to get a used header from someone who sold their mini.
I have an 2004 with alta exhaust,alta pulley, alta intake,Alta swaybar
Alta Air/Air Intercooler & H&R springs. Put down 180 on the Dyno last week
I like everything but the Alta Exhaust. I was the first one to order one from the 04 year. In 04 they changed the hanger positions. and We did some modifications to change the hangers. They should have fixed that problem by now.
I put 163HP down with the exhaust and Intake.
Old Oct 21, 2004 | 12:55 PM
D1JL's Avatar
D1JL
I am a Ca. Smog Tech. California is also OBD2 compliant.
If it does not turn on the MIL, it will pass the emissions part of the test. If the inspector looks close, it will NOT pass the visual test.
Dave
Old Oct 21, 2004 | 01:02 PM
stever's Avatar
stever
What is the MIL and why would it fail the visual inspection, it does have a CAT?
Old Oct 21, 2004 | 01:21 PM
D1JL's Avatar
D1JL
MIL stands for Maintenance Indicator Lamp. (Service Enging Soon Light)
The Catalytic Converter is located in the header.
The MM header uses a OBD1 Cat.
Dave
Old May 10, 2006 | 08:11 PM
Arly's Avatar
Arly
D1JL,
Where did you get the information that the MM header is OBD1? I have a Mania header and am plannning on replacing the cat with an Aftermarket Cat that is obd2 compliant.
chrisx18240
26
Mar 16, 2022 09:56 AM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
Aug 10, 2015 01:59 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
