Drivetrain spark plug heat range
Old Dec 13, 2017 | 12:07 PM
DRIVER1's Avatar
DRIVER1
Why would I need a higher heat range spark plug? I have a 2010 R55 Clubman John Cooper Works. Looking to buy your stage two kit and don't know if I need the higher heat range.
Old Dec 23, 2017 | 07:41 PM
sgscomps's Avatar
sgscomps
Here is some info on plugs and tunes http://jmtcperformance.com/tech-info...ing-and-setup/
Old Dec 23, 2017 | 07:57 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
A colder heat range plug will reduce the chance of pre-ignition. When you increase performance both cylinder pressure and temperature increases. The spark plug protrudes into the combustion chamber and is subjected to the increased heat. Without a colder range plug, heat can accumulate in plug to the point it can ignite the intake charge before it fires.
NGK 1422 - One heat range colder. In addition the gap is reduced from .032" to .024" which will reduce the chance of misfire under high boost.
danraabe
Dec 1, 2017 06:33 AM
Thinker2112
Cooper (non S)
May 23, 2017 07:51 AM
bratling
Dec 2, 2016 02:04 PM
Burkee52
Sep 23, 2016 05:54 PM
micro
R60/R61 Stock Problems/Issues
Sep 21, 2016 07:25 AM
