Drivetrain re Cam the R53 ?
Old Oct 2, 2017 | 08:08 PM
Montana Miniac's Avatar
Montana Miniac
re Cam the R53 ?
Could I get some feedback on changing the stock R53 cam for something more suitable (is there such a thing) for autocross? Is moving the torque band worth it?
Old Oct 3, 2017 | 04:04 AM
N2MINI's Avatar
N2MINI
Depending on what Class your already in changing the cam may force you to change classes. Unless you don't plan to tell anyone.. If you know where you need more torque at you might could get an ECU Tune to help if you haven't already... and if you added a cam you'd want to get it tuned as well to get the most out of it..
Old Oct 3, 2017 | 04:39 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
if you tune you are going to be in STX, if you put in a cam or pulley you are in SMF and then you can do damn near anything you want
I have a rmw dominator cam and i like it, but it's more top end
Old Oct 3, 2017 | 05:29 PM
BlwnAway's Avatar
BlwnAway
We all know what a cam change can do, esp dialed in for a specific use, but for track and rules compliance, I'm wondering about using an Adjusted Cam Gear, since all you're doing is tweaking what is already there.
Granted I was already heavily modified when I did mine, but it really helped the stock Cam out, +8 ft/lb of torque from 2700 up, to me it seems like a track car could really benefit from that.
Just a thought.
