Drivetrain The Turbo......To cover, or Not to cover?
Old Nov 8, 2017 | 07:39 AM
  #26
LostbutFound's Avatar
LostbutFound
You are right, I did highjack the thread a little. The point being heat control is important in a turbo engine. A rap is a good viable alternative to ceramic coating.
Old Dec 17, 2017 | 10:46 AM
  #27
Bnourai's Avatar
Bnourai
So dose the turbo needs to be removed to install MWM blanket? And why such price difference between M7 and way's?
Thx
Ben
Old Dec 17, 2017 | 12:07 PM
  #28
DneprDave's Avatar
DneprDave
No, the Turbocharger does not need to be removed to install the Way Motor Works turbo wrap.
What price difference? They are within a few dollars of each other.
But the M7 heat shield is only a heat shield, protecting the hood scoop but it does little else. It does not improve turbo efficiency
The WMW turbo wrap actually insulates the hot side of the turbocharger, keeping the heat inside the turbocharger and improving its efficiency.
Old Dec 17, 2017 | 12:11 PM
  #29
Bnourai's Avatar
Bnourai
Blanket
sorry meant to say Alta blanket
Old Dec 17, 2017 | 01:44 PM
  #30
DneprDave's Avatar
DneprDave
I didn't see the Alta turbo wrap available on Alta's website.
Old Dec 17, 2017 | 02:51 PM
  #31
Bnourai's Avatar
Bnourai
https://thmotorsports.com/i-1831636....nI5AZpka25XoiC
Old Dec 17, 2017 | 05:07 PM
  #32
DneprDave's Avatar
DneprDave
Thanks for the link. The WMW turbo wrap fits under the stock MINI heat shield, it appears that the Alta one does not. The Alta heat shield seems very overpriced for what it is.
Old Dec 17, 2017 | 05:24 PM
  #33
Bnourai's Avatar
Bnourai
That's what I thought if the materiel is the same why pay $$$$ more for alta.
Old Dec 18, 2017 | 07:08 AM
  #34
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The Alta fabric shield replaces the upper OEM factory heat shield, whereas the WMW wrap supplements the OEM factory shield. I thought I read the Alta was discontinued, too.
Old Dec 18, 2017 | 09:11 AM
  #35
Bnourai's Avatar
Bnourai
Great info thanks
Old Dec 25, 2017 | 11:36 AM
  #36
minimontes's Avatar
minimontes
the WMW is slightly modified from the "universal" blankets which i thnk Alta might be.
WMW altered the blanket to fit certain parts (feed lines i believe) for better fitment.
I would go with the WMW personally. especially since it fits properly under the oem shield, thus increasing the underhood heat decrease benefits.
the heat "shield" plates are more (imo) a "novelty" which have s light function, but more aesthetic function. the hood saver shield which attaches directly to the underhood instead of to the head are a much better choice if your looking to actually save the scoop.
Old Dec 26, 2017 | 10:35 AM
  #37
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Actually ours is not a modified version at all. We had these completely custom made from scratch using a stock turbo as a template to make them an exact fit. That is how they fit so tight and able to avoid the waste gate rod.
Old Dec 30, 2017 | 08:14 AM
  #38
minimontes's Avatar
minimontes
that what i was going for basically, lol, thanks for clarifying it.
I think we are all in agreement on this subject though to the best level of possible answer for your original question. if youre wanting the best solution at an affordable price without having to dismantle everything- WMW blanket is going to tbe the absolute hands down best product for heat control.
for aesthetic purposes afterwards, maybe throw on a plate. but dismantling and doing ceramic coating on everything- IMO is a waste and absurd.
Old Dec 30, 2017 | 10:12 AM
  #39
Bnourai's Avatar
Bnourai
Not so much of static person functionality is what's I'm after, if I can keep the temperature down under hood and have my turbo run more efficiently that means my CAI will do it's intended job I will be all for it.
Ben
Old Dec 30, 2017 | 11:53 AM
  #40
minimontes's Avatar
minimontes
Ben
The WMW blanket is going to be hands down the most effective for your application.
Old Jul 29, 2018 | 09:00 AM
  #41
Bnourai's Avatar
Bnourai
One more question, do I need to take the turbo out to use this wrap?
thx
Old Jul 29, 2018 | 09:12 AM
  #42
bugeye1031's Avatar
bugeye1031
Moderator
thx
No, the WMW blanket does not require the removal of the turbo....you will need to remove the stock turbo heat shield to gain access.
Old Jul 29, 2018 | 09:14 AM
  #43
cristo's Avatar
cristo
Alliance Member
does it fit the JCW turbo (2009) as well as it does the S one?
Old Jul 29, 2018 | 09:35 AM
  #44
Bnourai's Avatar
Bnourai
Great ordering now.
Ben
Old Jul 29, 2018 | 11:17 AM
  #45
WayMotorWorks
Vendor
YES it does
thx
No it just wraps around the hot side.
Old Jul 29, 2018 | 11:28 AM
  #46
bcriverjunky's Avatar
bcriverjunky
Open up the grill while your at it. https://www.waymotorworks.com/mini-f...oop-grill.html
