Drivetrain Supercharger cancel ?! Need ideas
Old May 22, 2017 | 03:54 AM
slide mini's Avatar
slide mini
​​​​​​​Hello every body
I have 2004 MCS supercharged
- 15% supercharger pulley alta
- 2% crank pulley alta
- big intercooler
- camshaft shark
- cylinder head ported intake manifold lines with standerd valves
- catback alta with manzo headers
- unichip
- ac compressor deleted
I modify my mcs To participate with track race in my country
The problem with me now in the rules of the race
The car should without supercharging system
So I need to delete supercharge
What can I do to get better performance without supercharger
I don't want to change engine or conversion to another engine
I want to do some thing to get minimum 160 hp without supercharger
The rules for race challenge
- maximum 2000 cc
- no supercharger
- no turbocharger
- no ITB
I would like to get your guidance and suggestions
Thanks to all
Ali
Old May 22, 2017 | 05:22 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move this to the Mod section.
At 2000 cc are you up against s2000 Hondas? You take the SC off and you back to a Justa.
Old May 22, 2017 | 05:36 AM
Guke's Avatar
Guke
I've heard of people wanting to turn their non-S into an S, but not the other way around. With the current prices of Mini's, I would think it might be cheaper and less work to buy and R50 and start with that.
Old May 22, 2017 | 07:22 AM
ST3ALTHPSYCH0's Avatar
ST3ALTHPSYCH0
Buy a justa and do a getrag swap?
Old May 22, 2017 | 12:06 PM
slide mini's Avatar
slide mini
I'm thinking to make mode. For intake manifold with bigger throttle as will
and change the piston with w10 engine piston
and delete the supercharger
allready I have the parts
The season will start on next October and I want to ​​​​​​​participate
Old May 22, 2017 | 12:11 PM
slide mini's Avatar
slide mini
what do you mean in justa !
​​​​​​​Thanks
Old May 22, 2017 | 01:59 PM
ST3ALTHPSYCH0
​​​​​​​Thanks
Non S car. Specifically, I was thinking pick up a low cost R50 and then swap in the Getrag 6 speed for a more reliable transmission.
Old May 23, 2017 | 02:20 PM
Eric_Rowland's Avatar
Eric_Rowland
"Justa" and in "I have a Cooper S, he has Just a Cooper."
Old May 26, 2017 | 09:36 AM
Derek86's Avatar
Derek86
By the time you are done converting your MCS to abide the rules, you should have just bought another car (or 2 or 3) to run. You are not going to get good performance running natural aspiration on an engine built for boost unless you overhaul the entire thing. Doing that makes little sense when you can get one of those engines in a different version of the car and it's cheaper.
So what's your budget and how competitive do you have to be?
Old May 26, 2017 | 11:08 AM
slide mini's Avatar
slide mini
hello dear
thanks for your support
I'm searching now for another MC R50
Old May 26, 2017 | 11:15 AM
Derek86's Avatar
Derek86
If you are stuck on Minis, I think that's your best bet.
Otherwise it depends what is available where you live. If you were in the US, I'd have a laundry list of cars for you.
Old May 26, 2017 | 11:25 AM
slide mini's Avatar
slide mini
I'm from Bahrain
here in Bahrain there are a few MC R50 with manual gearbox the most with AT
Old Apr 11, 2018 | 09:19 AM
slide mini's Avatar
slide mini
Rs engine for next season
Old Apr 11, 2018 | 09:44 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Racing with a slushbox! Cannot help but to notice the defunct shifter cables.
Old Apr 12, 2018 | 03:25 AM
slide mini's Avatar
slide mini
i will replace the gearbox with anthor Renault cable gearbox
