Drivetrain Short Shifter install problems!!!
Old Dec 5, 2016 | 06:40 PM
cw40342's Avatar
cw40342
I have a 2002 MINI Cooper S build date of 05/2002 I am trying to disconnect the shift cable that is connected to the shifter itself and I am having no luck at all.
Is there some kind of trick or tool to get the thing off?
Old Dec 5, 2016 | 06:58 PM
Racingguy04's Avatar
Racingguy04
I think there is a special tool that makes it easier, but I've never done it. Most reports I read involve those getting mangled and having to be replaced so take your time and do your research before you break them.
Old Dec 5, 2016 | 07:03 PM
Ol' Blue's Avatar
Ol' Blue
Nothing special it's just tricky. I usually get some bent needle nose pliers and kinda roll it to one side and that works.
Old Dec 5, 2016 | 07:49 PM
cw40342's Avatar
cw40342
I am trying as best I can to not destroy anything. I read on pelican parts install sheet he took an 14mm wrench and was able to pry down and remove it tried that did not work. The shifter doesn't need to be in any certain position or anything?
Old Dec 5, 2016 | 08:30 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
This is how we do it in the shop as it works the easiest. Just needle nose pliers on the shaft right above the ball and pop down.
Old Dec 5, 2016 | 09:14 PM
cw40342's Avatar
cw40342
Awesome I will try that and update!
Old Dec 25, 2016 | 02:54 PM
cw40342's Avatar
cw40342
Went to the local auto parts store got a nice set of 90 degree needle nose pliers worked perfectly!! Thanks for the help 👍🏻
