Drivetrain Manic Map Question
Old Aug 5, 2016 | 08:34 PM
  #26
Tigger2011's Avatar
Tigger2011
Alliance Member
Originally Posted by MiniMoic
Tigger, so do you belive the stock rods can handle 300hp? And only will be required to change pistons?
One of my clients is at that level now. Mahle pistons, stock rods, ARP rod bolts, ported head, custom hybrid KO4, Stage 3 + meth. He beats on it pretty regular and I tuned it a over a year ago.
Old Aug 8, 2016 | 05:53 AM
  #27
MiniMoic's Avatar
MiniMoic
Originally Posted by oldbrokenwind
I was running 312WHP on OEM bottom end for about a year before I rebuilt it with both rods and pistons. 'Course I didn't push it very often, but it held.
I know, I followed your build thread. I am myself deciding if I should forge the internals or not with my turbo.
Old Aug 9, 2016 | 10:56 AM
  #28
MiniMoic's Avatar
MiniMoic
Same CR? Size?
Old Aug 9, 2016 | 03:28 PM
  #29
Tigger2011's Avatar
Tigger2011
Alliance Member
10:1 with JCW head gasket. 47 mm compressor but shimmed for tighter clearance with a nine bladed turbine wheel instead of the usual twelve.
Old Aug 10, 2016 | 05:19 PM
  #30
MiniMoic's Avatar
MiniMoic
What other pistons will fit on stock rods?
Old Aug 11, 2016 | 06:57 AM
  #31
Tigger2011's Avatar
Tigger2011
Alliance Member
The stock rods are tapered on the small end so will fit on any of the aftermarket piston (CP, Mahle, Supertech, Wossner, etc). All of the aftermarket rods (CP, Pauter, PEC, ZRP, etc) are straight cut on the small end to provide additional strength. At the top of the stroke the weight and speed of the piston put quite a bit of stress in this area at high RPM. Hence the reason for the extra meat.
I usually recommend upgrading the rods at the same time since your already that far into it. In the case above the engine was already modded before the client came to me for tuning.
Old Aug 11, 2016 | 07:28 AM
  #32
MiniMoic's Avatar
MiniMoic
You´re right... You already have engine wide open. I can get ZRP rods not that expensive.
Old Aug 11, 2016 | 09:18 AM
  #33
Tigger2011's Avatar
Tigger2011
Alliance Member
ZRP and PEC are about the same price right now. Check both and pick your poison. ZRP also makes a forged 4340 chromoly crank for about $1450. Overkill for most though.
Old Aug 11, 2016 | 11:36 AM
  #34
MiniMoic's Avatar
MiniMoic
Thanks !!!
Old Aug 15, 2016 | 09:30 PM
  #35
velvetcows's Avatar
velvetcows
Originally Posted by thebombardier
I recently blew up my motor on Stage 2 Map B even though I was still running 93, which is the appropriate fuel for Map B.
Same scenario here. I had previously been running map C often. I also had some issues that likely contributed to engine failure. I might have been running 89 octane, I might've screwed up and pumped the wrong gas.
Replacement motor is in, hybrid turbo and HFS-4 installed.
Old Aug 16, 2016 | 05:18 AM
  #36
MiniMoic's Avatar
MiniMoic
Wow, Im start hearing about engine failures with MAnic tunes. Can you explain a litle more what was the failure itself?
Old Aug 16, 2016 | 01:46 PM
  #37
sub3622's Avatar
sub3622
Hey guys, does anybody know if manic tune stage 1 lower the temps just like stage 2 manic? or at least if it is possible to do it?
Old Aug 16, 2016 | 05:56 PM
  #38
Tigger2011's Avatar
Tigger2011
Alliance Member
Normally no. You would have to request it as a bespoke option but then it's the same cost as a Stage 2. The most obvious difference in the two is the temps and boost levels, There's a lot of other differences under the hood but you still get the DP CEL delete on both.
Old Aug 17, 2016 | 02:26 PM
  #39
sub3622's Avatar
sub3622
Tigger thank you for your kind answer. If that the case then how can someone get rid of the CEL?
Old Aug 28, 2016 | 03:06 PM
  #40
Tigger2011's Avatar
Tigger2011
Alliance Member
Wow. Not sure how I missed your question. My apologies for not answering earlier. The Stage 1 will delete the CEL for a highflow or catless DP. Most tunes will.
Old Apr 26, 2018 | 09:36 PM
  #41
Dgillrup's Avatar
Dgillrup
are the stages and maps a sliding scale of aggressive tune, to only be moved up according to fuel and parts? Basically 6 maps. Is Map C stage 1 safe in your opinion or are the C maps sketchy both stage 1 and 2?
Old Apr 27, 2018 | 07:03 PM
  #42
Tigger2011's Avatar
Tigger2011
Alliance Member
Stage 1, map C is as safe as Stage 2, map A. Boost levels are the same but performance is slightly less since it is designed for vehicles without the supporting mods a Stage 2 requires. Nonetheless, the harder you push any engine the greater the wear and tear as well as the chance of failure.
Old Apr 27, 2018 | 09:37 PM
  #43
yesti's Avatar
yesti
A: 1.3 bar, 18.8 psi
B: 1.4 bar, 20.3 psi
C: 1.5 bar, 21.7 psi
The stock S turbo can do ~18psi efficiently so map B is already pushing it a little. I wouldn't run a non-meth map C all the time without at least the JCW turbo but you're still putting more strain on the rest of the drivetrain.
Old Apr 28, 2018 | 04:19 AM
  #44
Dgillrup's Avatar
Dgillrup
these boost levels are for stage 1 and 2? Thanks!
Old Apr 28, 2018 | 11:22 AM
  #45
yesti's Avatar
yesti
AFAIK, yes, since stage 3 is for bigger than stock turbos. Although going from S to JCW turbo might qualify. Tuners, can a stage 2 S turbo map run a JCW turbo or is it worth a reflash?
Old Apr 28, 2018 | 11:34 AM
  #46
Tigger2011's Avatar
Tigger2011
Alliance Member
My mistake. In very early Manic revisions Stage 1 map C and Stage 2 map A were both 1.3 bar. Just checked my files and the below are current. Getting old sucks.
On the MCS
Stage 0
1.2 bar only
Stage 1
A 1.2 bar
B 1.3 bar
C 1.4 bar
Stage 2
A 1.3 bar
B 1.4 bar
C 1.5 bar
On JCW's
Stage 0
1.3 bar only
Stage 1
A 1.3 bar
B 1.4 bar
C 1.45 bar
Stage 2
A 1.3 bar
B 1.4 bar
C 1.5 bar
Old Apr 28, 2018 | 11:40 AM
  #47
Dgillrup's Avatar
Dgillrup
On the MCS
Stage 0
1.2 bar only
Stage 1
A 1.2 bar
B 1.3 bar
C 1.4 bar
Stage 2
A 1.3 bar
B 1.4 bar
C 1.5 bar
On JCW's
Stage 0
1.3 bar only
Stage 1
A 1.3 bar
B 1.4 bar
C 1.45 bar
Stage 2
A 1.3 bar
B 1.4 bar
C 1.5 bar
extremely helpful! Looks like I'll just stick it in stage 1 map C for the time being since I believe it was tuned for 91 when I have access to 93.
Old Apr 28, 2018 | 11:48 AM
  #48
Tigger2011's Avatar
Tigger2011
Alliance Member
Stage 3's are normally:
A 1.3 bar
B 1.4 bar
C 1.5 bar
But with meth some Manic tunes have been customized for higher depending on the size of the turbo.
MCS
A 1.4 bar
B 1.5 bar
C 1.6 bar
With 3.5 bar MAP sensors JCW's can go higher. For example mine is:
A 1.5 bar
B 1.6 bar
C 1.7 bar
Old Apr 28, 2018 | 11:55 AM
  #49
yesti's Avatar
yesti
Thanks! I love getting the inside scoop. So it seems that swapping an S turbo for a JCW is worth a reflash since the boost targets, among other things I'm sure, are different. BUT, would not getting it reflashed add extra insurance room since the tune isn't pushing the JCW "all the way"?
Old Apr 28, 2018 | 12:15 PM
  #50
Tigger2011's Avatar
Tigger2011
Alliance Member
I recommend a reflash when upgrading the turbo. While the pressures are the same the air flow is not. A larger turbo will flow more air at the same pressure. The MCS MAF sensor tops out at ~23 lbs of air and the JCW tops out at ~26 lbs of air. This equates to 230 bhp and 260 bhp. So at higher boost level the ECU cannot use the MAF sensor to calculate fuel injector duty cycle. Instead it switches to a table that calculates it based off of RPM with MAP and another table that defines the turbo's output. I know of a few customers have made the swap without a reflash. There are timing and lambda tables for component protection, but relying on those is not the ideal solution.
