Drivetrain Injector Upgrade?
Old Feb 9, 2016 | 06:20 AM
NathanMckee's Avatar
NathanMckee
Injector Upgrade?
I have the JB+ tune that I run at about 60%, and I want to see how much boost I can make without running lean? Can't find any info on injector flow or upgrade options. I just pulled 19psi on the stock turbo on a 5th gear pull on the highway. It seems to be running fine but I want to make sure I'm not pushing it...
Old Feb 16, 2016 | 11:00 AM
oldbrokenwind's Avatar
oldbrokenwind
I'm running OEM injectors, and have my boost controller set to 30PSI. Don't hit it often but it's there when needed. Other than HPFP reliability, the '07 MCS fuel system is pretty good.
Find a good tuner and have them set the AFR you want. I highly recommend Manic --- they gave me a 15% increase over an already awesome dyno pull.
https://www.northamericanmotoring.co...nic-dyno-1.jpg
Old Feb 17, 2016 | 05:30 AM
NathanMckee
That is amazing...
Manic has been something I have wanted to do, but my JB+ pulls really well, and I am monitoring ignition timing and EGT as I increase the aggressiveness of the tune. Glad to hear you can run that much boost on stock injectors!
Old Feb 18, 2016 | 08:21 AM
MINIMIKO's Avatar
MINIMIKO
Originally Posted by NathanMckee
That is amazing... Manic has been something I have wanted to do, but my JB+ pulls really well, and I am monitoring ignition timing and EGT as I increase the aggressiveness of the tune. Glad to hear you can run that much boost on stock injectors!
According to Jon from BMS , the only thing you need is a higher octane fuel
Old Feb 18, 2016 | 03:15 PM
NathanMckee
So I run 93 here up north, and gas quality seems pretty good. I hope that's enough since race gas at the local track is $10 a gallon..,
Old Feb 18, 2016 | 07:22 PM
MINIMIKO's Avatar
MINIMIKO
You can use torco
Old Jul 8, 2016 | 12:40 PM
ridinDirty's Avatar
ridinDirty
Spray 100% Meth and you got the octane when you need it.
Old Jul 10, 2016 | 07:17 AM
freestylin599's Avatar
freestylin599
if you're on stock turbo its pretty damn hard to lean the car out with the fuel system I'm running 20lbs through all gears on stock turbo, stock injectors with a brand new oem HPFP, on stock down pipe for 25k+ miles. The cars are built pretty strong
euror56er
Mar 7, 2016 05:48 PM
watk6412
Feb 10, 2016 02:40 PM
brandt004
Feb 4, 2016 12:59 PM
Tires, Wheels & Brakes
Jan 30, 2016 09:35 AM
brandt004
R55 :: Clubman Talk (2008+)
Jan 11, 2016 04:08 PM
