Drivetrain Boost leak test?
Old Aug 8, 2015 | 09:02 PM
johntotah94's Avatar
johntotah94
Boost leak test?
Anyone know how to properly perform a boost leak test on our cars?
Old Aug 21, 2015 | 12:16 PM
ryanschram's Avatar
ryanschram
I second this question.
Old Aug 21, 2015 | 04:08 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
See if this thread on NAM here my be helpful.
888.280.7799 | 6am - 5pm PST
Old Aug 22, 2015 | 09:07 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
the best thing to do is a smoke test as you can find all the leaks with that. But you will need someone with a smoke machine to do it for you.
Old Sep 11, 2015 | 07:08 AM
Indimanic's Avatar
Indimanic
Two ways
I made an adapter out of PCV with a tire valve stem that I put in the hot side boost tube and can apply air pressure up to 25 psi. This addresses the intake BEFORE the throttle body.
For the intake manifold itself; this is more touchy but a smoke machine from the exhaust tips will work or plug the tips and access through the O2 sensor port.
OR
Using the pre throttle method; plug the tips and have someone in the car ignition on open the throttle body then introduce the pressurized air.
One then has to listen for air leaks
I also made a smoke producing apparatus using some pipe, end caps and 2 small holes on either end and use tobacco to introduce the smoke then apply the air but generally one can track down via the noise using vacuum tube as a stethoscope.
Old Oct 5, 2015 | 03:05 PM
Helix13mini's Avatar
Helix13mini
We have both the high-pressure adapter and the lower pressure smoke test. The smoke test is easier to use, especially with small leaks that don't smoke up the whole engine bay.
Old Oct 19, 2015 | 02:20 PM
Indimanic's Avatar
Indimanic
Found these drain plug adapters that fit into the exhaust and seal perfectly.
Remove the hot side boost tube, put in adapter, turn on ignition to open throttle body then pressurize the system with air. Add smoke if a leaking noise is detected.
This pressurized the entire intake and exhaust systems
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
