Drivetrain K&N Air Filter
This Air Filter Claims added HP but has anyone tried it on a Dyno. Not such a radical change that I might consider before I get a cone filter. What do you guys think?
:smile:
:smile:
K&N makes great filters. I wouldn't buy one
to look for an increase in HP(slight..maybe).
They last forever......all you have to do is
clean them which some people may not think
of as 'fun.' :smile:
Check out K&N Filters
_________________
<IMG SRC=http://tiger.towson.edu/~ltowns1/me.jpg>
I'd rather be driving my S car!!
_________________
K&N now has their "filtercharger" flat-panel drop in replacement filter available for the S. I called K&N directly, the part number is 33-2270 and any place that carries K&Ns should be able to order it. At $35 and change helix13 has it for cheaper than the local Pep Boys I called (who's selling it for $48+ tax and shipping), so you may want just get it from helix13.
K&N does have a Typhoon Cold air system now for the "S".
You can even order it with various colors on the cold air tube.
Have just ordered mine from Summit Racing and can't wait to get it.
You remove the entire current air box, add the included heat shield, and install the kit. Seems pretty simple.
Looking at the K&N Typhoon instructions though, I'm confused as to why they don't have a heatshield that goes all the way around the air filter. In other words, they have three sides covered, but the fourth which faces the front of the car is exposed. Wouldn't that mean that the filter is prone to sucking in hot air?
Check out the instruction at http://www.knfilters.com/typhoon/69-2021.pdf
Replaced my stock air filter with a K&N panel filter (OEM style replacement) and noticed a little more power. The typhoon was way to much $$$. If you want something that elaborate and have the cash to burn the Madness or BMP is the way to go. The K&N panel filter is definitely the best cheap mod I can think of. I bought mine locally for $36, but prices vary. If you want one you might be better off just ordering from helix13 who also has it for about $35 + shipping.
>>was it pretty easy to install? ordered mine last week so it should be on it's way... thanks
... it's very easy: just take out a couple of torx screws and slide the cover off; lift out the old paper filter and tuck the K&N into place ...
.... replacing bags in the Hoover is harder ...
>>I can't wait till they make one for the S. Everything I drive
>>has a K&N....and no, I don't sell them....
Ditto, except the MINI. I plan on getting a MINI Madness intake when I can afford one but right now I'm running stock.
I have to say that adding a K&N drop in filter will give you a SLIGHT increase in HP and is probably the safest bet if you don't want to void your warantee. If you're not racing and/or aren't too concerned with squeezing power out of your MINI get the drop in replacement. They last forever and they give you a slight increase. I have one in my pickup truck and my two motorcycles. I plan on getting the pulley eventually so I'm not concerned with voiding the warantee.
-Chris
-Chris
It's funny that this thread has spung back into life as I just ordered the K&N filter and the cleeaning kit fro http://www.ajusa.com yesterday! (weired).
$44ish for both filter and cleaning kit.
I'll repost when I have it fitted.
Invoice details:
KN 33-2270 Item: K&N 33-2270: Replacement Air Filter
Fits:
1 $35.73 $ 35.73
KN 99-5000 Item: K&N 99-5000: Filter Care Service Kit Aerosol
Fits:
1 $8.68 $ 8.68
Sub-Total $ 44.41
Shipping $ 0.00
Total $ 44.41
Invoice details:
Fits:
1 $35.73 $ 35.73
Fits:
1 $8.68 $ 8.68
Sub-Total $ 44.41
Shipping $ 0.00
Total $ 44.41
Question...I read on another website some rather pointed criticism of K&N's filtering capabilities. That is, more air enters the engine, but the filtering is just not as good. They said its even worse after cleaning. (...looked for the thread but haven't found it yet) Anyway, any thoughts on this??? My concern, of course, is possible impacts to the warranty. This other thread spooked me. What's the straight scoop!
I've actually read the same thing. The gist I get is that, it filters pretty darn well, but a little scudge in there is going to happen either way. No matter what, it's probably negligible and won't harm your engine. Anyone else care to share experiences/thoughts?
-Troy
-Troy
I have not got it yet, Delivery via UPS ground look like 2 weeks from order. Should get it the 15th.
If your worried about warrenty you can always pop the original filter back in before you take it to the dealers. There are no permanent modifications with a drop in filter. Sneaky I know. But not actually unhonest unless they ask you "Did you swap this filter out anytime?" Lol.
I do not expect to have any warrenty problems.
As you mod the car more and more you put extra strain on the engine and it might effect the life a few years down the line. But a drop in filter? Nah, I dont imagine you will have any problems!
I'll do a photo shoot if the installation for the newbies (like myself) when it arrives.
:smile:
:smile:
