Drivetrain Anyone know anything about the GFB DV+?
Old Feb 14, 2015 | 09:55 AM
TheSkyIsUp's Avatar
TheSkyIsUp
http://www.gfb.com.au/products/blow-...ication-by-gfb
would be going on a N14 engine, I'm curious if it would throw off any codes mainly.
Old Feb 14, 2015 | 10:02 AM
Zillon's Avatar
Zillon
Shouldn't.
It's a stronger diverter valve. Stiffer spring. Quicker actuation. Holds boost better.
I had one in my GTI and liked it. Would love to put one on my GP, but they haven't made a manual N18 fitment yet.
Old Feb 14, 2015 | 10:06 AM
TheSkyIsUp's Avatar
TheSkyIsUp
Originally Posted by Zillon
Shouldn't.
Thats what I was thinking, thanks!
I was originally just going to get a stronger spring from ALTA, but I've read that the stock DV is plastic and doesnt hold up as well as an aftermarket metal one.
Old Feb 15, 2015 | 11:29 AM
Grizld700's Avatar
Grizld700
I can say I really love it!. I had an uprated DV from a MINI vendor before. It was a nice upgrade. But once I got my tune I noticed it still had some limitations (although not that much). I got the GFB DV+ and with my tune this thing rocks! It holds the boost like I want it to. No longer is it an on-off switch ( really hated that). I can adjust my throttle through turns and not have the DV dump boost right away. Plus I can rest knowing I will never have to worry about a torn DV diaphragm. I say, if you find one used get it! It'll be just as good as a new one! If and when you do get the DV+ just be sure to lube the piston wall with a little oil. It's a step I've seen some people forget/skip.
Old Jul 18, 2015 | 10:50 PM
donniedarko's Avatar
donniedarko
Im installing one tmrw. Does it make sense to use the Alta Spring with the DV+? I have it never installed it
Pker
Apr 11, 2017 12:14 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
johntotah94
Jul 31, 2015 08:58 AM
monaco23
Jul 11, 2015 11:13 AM
donniedarko
R55 :: Clubman Talk (2008+)
Jul 10, 2015 11:01 PM
