Drivetrain ko4 upgrade
Old Jan 6, 2015 | 06:50 PM
minivinnie92's Avatar
minivinnie92
ko4 upgrade
Ok so my brother friend is upgrading his 2013 mazdaspeed3 and was offered his stock ko4 for 300$ what would it take for me to bolt that to my 2011 Cooper s ? Can I run safely for a little bit without a tune? I will also b installing meth once the weather gets warmer if that helps I assume some of the mounts maybe different? I am a full time mechanic but turbos are a difdifferent world to me any advice is well appreciated thank you in advance
Old Jan 6, 2015 | 07:04 PM
cerenkov's Avatar
cerenkov
I don't believe that it is a bolt-on replacement. Not worth the trouble even if it was free.
Old Jan 7, 2015 | 07:49 AM
R53Warrior's Avatar
R53Warrior
its nowhere near a bolt-on affair. Different on both sides of the turbo. I would not run a K04 without a tune.
Old Jan 7, 2015 | 08:00 AM
Saltysalt's Avatar
Saltysalt
I think there be a lot of work involved to getting a mazda ko4 into a mini, I believe the mazda ko4 and a audi/vw ko4 are different as well. I believe mini mania has a upgraded turbo that has ko4 internals... that is what you should look into.
as far as I can see right now, with that turbo you would need a tune, exhaust manifold, down pipe, and new piping. might be more work than willing to give.
could it be done? prolly. worth doing? that's up to you
Old Jan 8, 2015 | 04:34 PM
minivinnie92
So if I got the turbo cheap enough would it be worth it for the internals? I assume my factory turbo would need to be machined? Is that safe?
Old Jan 8, 2015 | 04:45 PM
MarioKart's Avatar
MarioKart
Vendor
I have ran K04's on stock tune minis and just kept the RPM's below 4K kill it was tuned. I logged it and everything was good, if you drive it mild
mQubed Motorsport, Manic Tuning Dealer
Old Jan 8, 2015 | 05:44 PM
minivinnie92
Ya I mean I'm gonna a get tuned regardless but what am I looking at in order to swap internals?
Old Jan 8, 2015 | 05:49 PM
MarioKart's Avatar
MarioKart
Vendor
Not sure about internals with out getting the housing milled out. Might be a headache with out the right connections.
Old Jan 9, 2015 | 06:00 AM
Grizld700's Avatar
Grizld700
A Mazda K04 will not work on a MINI with a lot of fabrications. It is different than a K04 that is built for MINI application. Just google 'Mazda K04' and then compare it to the K04 offered by JMTC. Not even close.
Old Jan 10, 2015 | 09:52 PM
oldbrokenwind's Avatar
oldbrokenwind
Mini turbo waste gate works on a vacuum. I'm told that most others work on positive pressure. If your Mazda turbo doesn't use a vacuum, that's one more "adaptation" you need to make. Might also make getting a tune harder --- dyno vs. remote tuning.
Swapping internals eliminates the mechanical fit problem, but introduces other issues --- reliability, etc. I suggest you consider a turbo swap with a well-respected vendor that has Mini turbo experience --- IF you really want a "bigger" turbo.
Old Jan 11, 2015 | 05:13 PM
minivinnie92
Ah I will have to go that route was just hoping it would be close with little modification needed because of the price
Old Jan 11, 2015 | 06:33 PM
Porthos's Avatar
Porthos
You could get it to work but, it would not be worth the price to do it. Just get a JCW turbo instead for a few bills more.
Old Jan 12, 2015 | 02:47 PM
minivinnie92
Ya that's what I will end up doing when I am done with tune and meth kit install
molala
Oct 2, 2015 01:53 PM
Sep 10, 2015 10:52 AM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
