Drivetrain Snow Tires
Old Nov 29, 2014 | 04:16 PM
cw40342's Avatar
cw40342
Snow Tires
Ok I've read some threads on tire sizes but I can't ever find a definite answer. I'm wanting to run a 205/50/17 simply because you get more tire options can this be done? Will I have issues with rubbing steering or anything?
Old Nov 29, 2014 | 05:46 PM
hsautocrosser's Avatar
hsautocrosser
205/50-17 is about 0.9" taller than a 205/45/17. Your ground clearance will be increased by half that amount (good for snow) and the other half will reduce the clearance between your tires and fenders. Unless you have lowered the suspension you will be well clear of rubbing.
Old Nov 29, 2014 | 05:51 PM
cw40342's Avatar
cw40342
I may lower later on but I'm most likely going to do coil overs so winter I can just raise the suspension
Old Nov 30, 2014 | 10:58 PM
bmwr606's Avatar
bmwr606
mini seems to put much smaller od tires on their cars than they can accommodate
my cms all4 came stock with 225/45R18s (25.9 inch od)
i put 205/70R16 (27.3 inch od) winters on the car and have no rubbing issues at all
Old Nov 30, 2014 | 11:13 PM
cw40342's Avatar
cw40342
Originally Posted by bmwr606
mini seems to put much smaller od tires on their cars than they can accommodate my cms all4 came stock with 225/45R18s (25.9 inch od) i put 205/70R16 (27.3 inch od) winters on the car and have no rubbing issues at all
I agree with the tire sizes for sure. I've looked at measurements of different tire size most aren't far off from the stock size. Seems like they are trying to make it harder to find tires
Old Dec 2, 2014 | 09:31 AM
Saltysalt's Avatar
Saltysalt
FWIW I run 215/45/17 for winters and summers, winters are on OEM Slites, no rubbage or anything, summers are on OZ's and I do get some rub in the back under hard hits
Old Dec 7, 2014 | 03:13 PM
cw40342's Avatar
cw40342
Anyone run falken euro winter
Waszak
Oct 21, 2017 05:55 PM
Southern Marylander
18
Sep 18, 2015 07:16 PM
dpike
Sep 12, 2015 08:19 AM
Ntety
Sep 2, 2015 08:39 PM
