Drivetrain 2003 mini
Old Nov 12, 2014 | 08:48 PM
blazerpat's Avatar
blazerpat
2003 mini
how do i fix not going into reverse? new clutch 4 months ago. working fine until now. Any schematics that show shift mechanism ?
Old Nov 12, 2014 | 08:54 PM
csgirardeau's Avatar
csgirardeau
Could you elaborate on your problem?
As far as I'm concerned, you need to push with some force to the left and then up to go into reverse. For first gear you lightly push left and then up or diagonally to the top left corner towards 1st.
Sorry if I'm sounding like a douche! Some people call cable companies asking why their TV isn't working when it somehow got unplugged!
Also, is it a manual or a CVT?
Old Nov 12, 2014 | 09:05 PM
blazerpat's Avatar
blazerpat
manual . can get into reverse if go to third then second .
Old Nov 12, 2014 | 09:15 PM
csgirardeau
So are you saying that it's impossible for you to go into reverse without going into third and second before?
Old Nov 12, 2014 | 09:29 PM
blazerpat's Avatar
blazerpat
yes
Old Nov 12, 2014 | 09:49 PM
csgirardeau
I'd search for any problems with whatever brand the clutch is online.
I've never heard of this problem and it sounds very strange to me. If worst comes to worst, you can take it to a specialized mini/ bmw mechanic and explain your problem.
Old Nov 13, 2014 | 08:08 AM
quikmni's Avatar
quikmni
I do not know much about which cables move for which gears, but maybe it is a shift linkage or shift cable problem.
realoem and penskeparts have part schematics. Do you have a Bentley Repair Manual?
Here is an image from realoem but probably does not have the detail you need:
Old Dec 3, 2014 | 07:15 AM
Tuningcars's Avatar
Tuningcars
It could be a problem with the linkage, in that case it has nothing to do with the clutch, but only if it is the linkage, I had to replace my linkage system about 5 months ago, it was VERY hard to get into 5th and 6th.
Hope you get it resolved!
Old Dec 3, 2014 | 08:54 AM
Mib4840's Avatar
Mib4840
Try lubeing the pivot points and cables see if that helps
SosoMINI
Nov 22, 2015 03:17 PM
bc219
Aug 10, 2015 11:22 AM
Dashdog
Aug 10, 2015 06:17 AM
joelcseymour
Aug 7, 2015 12:43 PM
