Drivetrain Will a R53 Short Shifter fit on a R56?
Old Jul 5, 2014 | 10:11 PM
LAcooper's Avatar
LAcooper
As the thread states, is a r53 short shifter compatible with a r56?
Old Jul 6, 2014 | 06:15 AM
ACallahan's Avatar
ACallahan
No, I could possibly be wrong, but I had a R53 short shifter that would not even fit a facelift R53(2005).
Old Jul 6, 2014 | 09:27 AM
1qwkmini's Avatar
1qwkmini
Depends on which year R53--05/06 with the new shift box (black under the shift boot) will fit. 04 and prior has a smaller diameter shift rod.
Old Jul 7, 2014 | 10:33 AM
CravenSpeed's Avatar
CravenSpeed
Vendor
I respectfully disagree. While the main ball is the same size on the facelift and the R56, the sockets where the cables attach are not the same.
Old Jul 7, 2014 | 11:08 AM
1qwkmini's Avatar
1qwkmini
I don't know where you get your logic!!! If the ball is the same size then the sockets will be the same size--only one of the cables is affected by the short shifter. FYI, if you look up the Helix short shifter, you will see that there is one for 02-03 and one for 04 to current----http://www.detroittuned.com/helix-short-shifter/
Old Jul 8, 2014 | 09:29 AM
CravenSpeed
Vendor
Its not a question of logic. The shifter has to manipulate both cables, you are correct that both do not plug directly into the shifter, but the shifter has to attach the arm that manipulates the other. The 04-06 shifter will not fit the bushing on that arm for the 07-13 shifter.
As noted; The Helix adapter will fit all of those years; because the bushing in question is not affected.
Just trying to help.
Aug 12, 2015 01:24 PM
jcb-memphis
Aug 8, 2015 11:09 AM
Aug 7, 2015 05:56 AM
