Drivetrain Crank pulley selection
Old Jul 7, 2015 | 11:05 PM
  #26
GearheadS's Avatar
GearheadS
I'm pretty sure I used the stock bolt with my Speedmaster. I did need a longer one to start pulling it on.... Or did I drive it on with a hammer and wood block? Don't remember for sure. But the stock bolt is what I ended up with.
Old Jul 8, 2015 | 08:40 AM
  #27
drrigg's Avatar
drrigg
Bolt problem solved. It turns out the bolt fits much better if you pull the harmonic balancer bolt out of your pocket and use it instead of waiting until you hear it banging around in the washing machine hours later after trying to make a much smaller bolt fit in the crank. Sometimes I make it so difficult!
Old Jul 8, 2015 | 10:25 AM
  #28
GearheadS's Avatar
GearheadS
Haha! "Sandblasting" the inside of the washer?? Glad you figured it out
Old Oct 17, 2015 | 03:52 AM
  #29
Hobine's Avatar
Hobine
Originally Posted by GearheadS
Still works fine.
Still working fine? Thinking of picking one of these up.
Old Oct 17, 2015 | 05:25 AM
  #30
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Just finished reading this thread and have to comment on post #21 by bmdouble. I've been using a PRW damper for at least 3-4 years, running it to 7k redline repeatedly (Thanks to Way's tune!) with no issues whatsoever. Had I received a defective unit, I would've contacted PRW for a replacement.
Old Oct 17, 2015 | 06:36 AM
  #31
GearheadS's Avatar
GearheadS
Yeah Hobine, the Speedmaster is still working fine. This is my wife's daily driver and our trip car, so it probably has 25k miles on it now.
Old Feb 3, 2019 | 04:31 AM
  #32
BruceJ's Avatar
BruceJ
PRW installed here. None of the wobble that was mentioned earlier. Heated in oven for 30 min at 275, went right on the shaft.
Old Feb 6, 2019 | 10:21 AM
  #33
IQRaceworks's Avatar
IQRaceworks
Buy once....cry once. Buy the ATI and be done with it
Old Feb 7, 2019 | 09:40 AM
  #34
BruceJ's Avatar
BruceJ
Just installed PRW, no low RPM wobbles, slipped right on after heating for 30 min at 275 deg F.
Old Jul 15, 2025 | 06:26 AM
  #35
Oestergaard's Avatar
Oestergaard
Hi GearheadS now it is more than 10 years, how is that Speedmaster doing?
Old Jul 15, 2025 | 06:37 AM
  #36
Oestergaard
Hi GearheadS
I am thinking to get the Speedmaster crank Pulley, so just wondering if still doing awesome?
Old Aug 4, 2025 | 02:57 PM
  #37
GearheadS's Avatar
GearheadS
Originally Posted by Oestergaard
Hi GearheadS
Sorry for the delay... Yes, haven't touched it since! Lots of miles on it.
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
boydie
Sep 13, 2015 05:06 PM
larryd96
11
Sep 8, 2015 05:01 AM
M7Speed
Sep 3, 2015 07:48 AM
