Drivetrain Higher Octane
Old Jun 8, 2004 | 01:48 PM
ColoradoMark's Avatar
ColoradoMark
Higher Octane
Will higher octane unleaded race gas increase performance on a pullied/stock ECU MCS?
I'm at the track this weekend and just received an email that they will have up to 107 octane gas available. Would it help (at 5000 feet elevation)?
Old Jun 8, 2004 | 02:54 PM
Bisch's Avatar
Bisch
You may get an extra hp or 2. Nothing significant. Be sure you use UNLEADED race fuel.
Old Jun 8, 2004 | 03:04 PM
Trippy's Avatar
Trippy
I doubt it.
But let us know if you think it does.
Old Jun 8, 2004 | 04:24 PM
jazmini's Avatar
jazmini
It may be that you would need to have your ECU prepped for the higher octane to make a difference?????
Old Jun 8, 2004 | 04:59 PM
LilRedMini's Avatar
LilRedMini
I expect that jazzmini is right. Once you have a high enough octane to keep the knock sensor from retarding the timing, any octane increase above that is wasted. If they can flash a chip with increased timing advance, then you could probably take advantage of it. That much timing advance may be out of the range that they have to work with.
Good luck,
Old Jun 9, 2004 | 06:15 PM
d6-mcs's Avatar
d6-mcs
91 is the optimal octane rating need for optimal performance. putting high octane fuel in the car will not do anything.
Old Jun 10, 2004 | 01:12 PM
Bisch's Avatar
Bisch
This is true...if it is a bone stock engine.
Old Jun 10, 2004 | 01:53 PM
MOTORN's Avatar
MOTORN
Right and also stock ECU :smile:
Old Jun 10, 2004 | 02:24 PM
ColoradoMark
Well, that's probably good news - I won't be temped to pay $4.00 a gallon for the fuel!
Doc Pain
Mar 10, 2021 04:50 AM
MGBill1186
Oct 2, 2015 06:54 AM
Sep 25, 2015 11:46 AM
Sep 25, 2015 11:44 AM
Mini ni
Sep 24, 2015 05:42 AM
