Drivetrain Oil Pressure Switch Replacement
Old Mar 22, 2014 | 10:20 PM
OCVeloman's Avatar
OCVeloman
So i have again over complicated a simple project. I get an oil pressure light on idle and it goes away under acceleration; no other symptoms so it seems, from reading, that my switch is bad. I ordered one and a 27mm deep socket to be prepared, removed the heat-shield and the little red clip from the connector which i then dropped into the engine bay and now cannot find :( . Even after removing the evasive red clip pin, i cannot get the green connector off the original switch! I grab it, shake it back and forth, have even tried plying it toward the firewall with a screwdriver to no avail. Anyone have any tips or tricks? I think i am going to remove the passenger front wheel tomorrow to look for the little red clip i dropped, would it be easier to access from there? Any advise is greatly appreciated!
Old Mar 23, 2014 | 05:46 AM
1qwkmini's Avatar
1qwkmini
The red clip is a safety clip--you still need to push down the retaining tab before it will release. The tab near the wiring--push the plug into the sensor and push down on the tab, then it should be easy to pull off.Name:  AM_Electric_OP_003.jpg
Old Mar 23, 2014 | 09:20 AM
OCVeloman's Avatar
OCVeloman
THANK YOU!!! My sensor is upside down so i can't see a tab and getting the red thing out was a bear. Appreciate the reply.
Old Mar 23, 2014 | 09:51 AM
1qwkmini's Avatar
1qwkmini
BTW--you don't need to remove the red keeper all the way--it's just a safety tab. When you get it all out and replace it, you will see that it will stop while on the plug but you will still be able to activate the other tab.
Old Mar 23, 2014 | 12:24 PM
OCVeloman's Avatar
OCVeloman
thanks for the help! got it done this morning. Old connection and sensor were dripping oil so I'm thinking this will fix it. I will report next week once i get the car back together.
Old Apr 1, 2014 | 10:17 AM
OCVeloman's Avatar
OCVeloman
After 100 miles, no light! seems the sensor was acting up. Thanks!
Old Apr 1, 2014 | 10:18 AM
1qwkmini's Avatar
1qwkmini
No problem that's what we are all here for.
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
blackie
Jan 18, 2017 09:56 PM
Emnotek
Aug 13, 2015 05:47 PM
