Drivetrain How to eliminate AC
Old Feb 11, 2014 | 12:25 PM
daonlyillwiz's Avatar
daonlyillwiz
How to eliminate AC
Well considering that my mini is not a daily driver, i have no use for the AC system. I would like to remove it... i know i need the AC delete idler pulley which is fine, but does any one have any tips/tricks on the best way to do this ? Also by removing the AC will it display any check engine lights/trouble code ?
I will be purchasing this
http://new.minimania.com/part/NME506...-Mini-Cooper-S
Old Feb 19, 2014 | 06:04 AM
daonlyillwiz
bump
Old Feb 19, 2014 | 07:21 AM
astroBlackMetallic_Mini's Avatar
if its not your daily, does it really matter if you throw codes? im assuming youll be doing other engine mods as well... if your going to throw one code, might as well say F it and do whatever else you want regardless of codes, just let them come!
Old Feb 19, 2014 | 07:23 AM
daonlyillwiz
lol, cant do that because i have to be able to inspect the car when the time comes. Im in NY and they are a PITA here..
Old Feb 19, 2014 | 04:28 PM
Da_Ghost's Avatar
Da_Ghost
- Take the Mini to a shop.
- Get the system emptied.
- Remove anything A/C related (If you plan on re-installing it, don't bother removing the evap, just plug the tubes with plastic caps.
- Install a/c delete idler.
- Remove the pressure switch from the a/c lines and hook it back up on its connector, otherwise the fan will always be on with the car running.
- Profit????
No, it won't throw a light. I've deleted mine last year and I have no problems at all.
Old Feb 19, 2014 | 05:08 PM
daonlyillwiz
Originally Posted by Da_Ghost
- Take the Mini to a shop. - Get the system emptied. - Remove anything A/C related (If you plan on re-installing it, don't bother removing the evap, just plug the tubes with plastic caps. - Install a/c delete idler. - Remove the pressure switch from the a/c lines and hook it back up on its connector, otherwise the fan will always be on with the car running. - Profit???? No, it won't throw a light. I've deleted mine last year and I have no problems at all.
Perfect, now where is this pressure switch ?
Old Mar 5, 2014 | 08:35 PM
wmcginnis's Avatar
wmcginnis
Pressure switch is on the smaler ac line under the airbox, back by the shifter cables
Old Mar 6, 2014 | 07:18 AM
daonlyillwiz
thx wmcginnis, im gonna be tackling this some time in spring when temps are above 60*, its simply too damn cold in NY to do anything.
Old Mar 6, 2014 | 11:50 AM
minibx's Avatar
minibx
Daonlyillwiz just in case I forgot to redirect you before there are a couple of runs that you may want to join since they are a ton of fun, you can join at NEMINI.org
So do whatever you have to do before April 27th lol
Old Mar 6, 2014 | 01:48 PM
daonlyillwiz
im already on nemini.org, and i should be there
Old Mar 7, 2014 | 12:42 AM
TonyB's Avatar
TonyB
- Profit????
Have you noticed any issues with fogging on the interior of the windshield? A/C units are supposed to assist with moisture removal in such circumstances... Thanks.
miniuy
Sep 21, 2015 02:00 PM
Timmy_r53
Sep 14, 2015 01:59 PM
MINI-Madness
Sep 11, 2015 11:31 AM
Sep 2, 2015 09:05 AM
