Drivetrain A Day at the Dyno
Old Jun 1, 2004 | 03:00 PM
  #26
friedduck's Avatar
friedduck
Is there a way to extract the boost numbers coming from the MAP sensor? That'd offer a clue about what the engine's doing...
Jeff
Old Jun 1, 2004 | 03:06 PM
  #27
andy@ross-tech.com's Avatar
andy@ross-tech.com
Sure, the MAP sensor IS the same thing as boost ... well, absolute presssure.
Old Jun 1, 2004 | 03:59 PM
  #28
Technomage's Avatar
Technomage
Here is the data I have handy:
#1:
Ext Air Temp: 72.8 F
Humidity: 50%
Altitude: 52 ft
Absolute Pressure: 29.7 in-Hg
Vapor Pressure: 0.4 in-Hg
about 1 to 2 hours later:
Ext Air Temp: 78.2 F
Humidity: 37 %
Altitude: 52 ft
Absolute Pressure: 29.8 in-Hg
Dyno was done inside a well ventated garage with a 4' floor fan blowing at the open bonnets.
Old Jun 2, 2004 | 07:15 AM
  #29
andy@ross-tech.com
Again, did you monitor the ECT and IAT for each vehicle? Those are the Engine Coolant Temperature and Intake Air Temperature, not anything relating to the ambient conditions. The reason I ask is that I have seen wild swings in numbers for the same car on the same dyno, when those temperatures vary by more than a few degrees. By stabilizing those temperatures by either allowing the car to idle or to sit with the engine off, it is possible to get remarkably repeatable output figures throughout the day.
JaysinStrife
Jun 3, 2016 09:19 AM
USA-RET
Nov 9, 2015 07:27 PM
M7Speed
Sep 4, 2015 10:47 AM
M7Speed
Sep 3, 2015 07:48 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
