Drivetrain Belt tensioner tool
Old Jun 4, 2004 | 04:09 PM
  #26
andy@ross-tech.com's Avatar
andy@ross-tech.com
Bad belt tensioner tool!
Old Jun 4, 2004 | 04:42 PM
  #27
andy@ross-tech.com
Here's the repaired tool:
Old Jun 5, 2004 | 06:25 AM
  #28
norm03s's Avatar
norm03s
>>I think no one is responding because the word on the street is that measuring the belt tensioner tool voids the warranty.<<
BigBrownDog,
Think I'll just be persistant,, Anyone want to take the measurements and post them?
Old Jun 5, 2004 | 10:03 AM
  #29
dennisyvonne's Avatar
dennisyvonne
Andy, Aprox. how many times was the tool used prior to breaking it ?
Dennis
(Just bought one)
Old Jun 5, 2004 | 10:26 AM
  #30
andy@ross-tech.com
That tool was used ONCE (when I installed the 19% pulley). If I were to do it over again, knowing what I know now, I'd get that tool rewelded before its first use. The worst scenario would be the tool breaking after the belt is off.
Old Jun 5, 2004 | 10:45 AM
  #31
Bisch's Avatar
Bisch
...The belt tensioner can be unloaded with a simple 1/8" X 1" flat bar stock. the tool is a waste of money! Use the bolt head as the leverage point, and the bar stock pries up on the curved armature of the tensioner bracket. Simple.
Old Jun 5, 2004 | 10:49 AM
  #32
andy@ross-tech.com
>>" As I almost have it in the place, the tool snaps in half right where it is welded together! A half a second sooner and my fingers would have been stuck between the belt and the pulley! " I have heard this story before from different folk's.
>> And here I thought I was all slick because I bought the tool for the job, when I would have been better off making my own.
>>I will follow your suggestion and make my own if you would please measure and post the distance between two pins that fit into the side of tensioner, diameter of pin's the rest I can figure out from pic's. Thanks,............. norm
The pins appear to be 5mm diameter, and they protrude 10mm from the tool. Their centers are 35 mm apart.
Old Jun 5, 2004 | 01:34 PM
  #33
norm03s's Avatar
norm03s
>>>> :smile: :smile: :smile: :smile: :smile:
Old Jun 5, 2004 | 01:37 PM
  #34
dennisyvonne
That is bad news. Got mine today and they have added a couple of extra welds. Hope it holds up. I'll find out tomorrow when I join the 19% gang.
Dennis
Old Jun 7, 2004 | 07:02 AM
  #35
norm03s's Avatar
norm03s
Tensioner tool puchase
dennisyvonne, If I may ask, where did you buy from.
Old Jun 7, 2004 | 07:13 AM
  #36
andy@ross-tech.com
I got mine from my local MINI dealer, about $60.
Old Jun 7, 2004 | 07:32 AM
  #37
norm03s's Avatar
norm03s
Andy, your measurement's worked fine. I made one up this weekend it's a little different because the handel is removable but it work's on the same principal. :smile:
Old Jun 7, 2004 | 07:58 AM
  #38
2Cool's Avatar
2Cool
Mine broke in the same spot, same lack of factory welds. First use I was pulling toward me, it snapped, I fell backwards, catching myself on the utility sink in my garage. Annoyed is a slight understatement for my feelings then, especially after seeing the crappy welds. I welded it like Andy did, but I also put a diagonal cross bar from the lower end to about 6" up the handle, for my peace of mind.
Though my welds aren't quite as pretty as Andy's... nothing a grinder and paint didn't take care of...
Old Jun 7, 2004 | 08:12 AM
  #39
Bisch's Avatar
Bisch
[QUOTE=2Cool]Mine broke in the same spot, same lack of factory welds. First use I was pulling toward me, it snapped, I fell backwards, catching myself on the utility sink in my garage.
OMG. How much force were you applying? I'm not going to try to open a debate, but is it possible that too much force is being applied? I have not found too much resistance from my tensioner.
Old Jun 7, 2004 | 08:22 AM
  #40
andy@ross-tech.com
In my case, the tool didn't snap, it just bent at the weld. I was applying enough force to get the spring tensioner to compress to the point where the second hole was visible, no more, no less. I felt a weird sensation that part of the tool was made of taffy. Inspection revealed the weld between the handle and the "ring" was indeed made of taffy!
I broke the ring by trying to bend the handle back into position.
Old Jun 7, 2004 | 08:25 AM
  #41
Bisch's Avatar
Bisch
Taffy bar! ...with bubble gum welds?
Old Jun 7, 2004 | 03:00 PM
  #42
dennisyvonne
Got mine from "Out Motoring" I found out that they were only the middle man. Had no problem with mine, but as I said before it had been re-welded. Changed my Alta 15% to Alta 19% in 1 hr and 15 min. Did a slight motor raise on pulley side and removed fender skirt.
Dennis
Old Jun 7, 2004 | 03:14 PM
  #43
2Cool's Avatar
2Cool
How much pressure? One hand pulling toward me as the other was reaching to pin the tensioner with a screwdriver. It never even made it to where I could pin it up, before the tensioner broke... snapped off completely exactly as shown in Andy's pics. The only welds were on either end, nothing in the middle, which left that small semi-circle of metal to hold the entire force. It dinna work too well, Cap'n.
Got mine from Outmotoring too, and they offered a replacement. I was impatient and just welded it up myself. No complaints on Outmotoring, good service there, big complaints on a factory Mini tool quality.
elverado
Jan 18, 2022 02:51 AM
patsum
26
May 29, 2021 06:29 PM
hong
Sep 13, 2015 06:41 PM
Emnotek
Sep 11, 2015 04:16 PM
Sep 8, 2015 11:37 AM
