Drivetrain oil filter housing tap for oil temp gauge
Old Jan 8, 2014 | 03:56 PM
knuckleheadbob's Avatar
knuckleheadbob
curious if anyone has tapped the oil filter housing for an oil temp gauge
Old Jan 8, 2014 | 06:56 PM
bmwr606's Avatar
bmwr606
from prosport gauges, this is for a bmw, but i have a friend that is a machinist and i was thinking of him making me one like this for the mini n18
http://prosportgauges.com/bmw-oil-fi...-7-Series.aspx
Old Jan 8, 2014 | 07:41 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
this tap will make your life much easier
http://waymotorworks.com/oil-pressur...9-r60-r61.html
Old Jan 8, 2014 | 07:47 PM
bmwr606's Avatar
bmwr606
i have one for the oil pressure, but wonder how good it would be for temp as there is no flow of oil, it is a dead end
edit: my other thought is to weld a bung on the oil pan
Old Jan 8, 2014 | 07:55 PM
vetsvette's Avatar
vetsvette
Moderator
I just use my Scangauge II to read oil temps.
Old Jan 8, 2014 | 08:17 PM
bmwr606's Avatar
bmwr606
i have a scan gauge II for now, but i bought 5 prosport 1.75" diameter electric gauges for my final setup. i am on my 3rd gen mount for them
i got oil temp, oil press, water temp, boost and volts
ideally, i would like to measure the oil temp in the pan, but do not want the temp probe sticking straight down out of the drain plug
Old Jan 9, 2014 | 02:57 AM
knuckleheadbob
doesn't seem to be to many good places to pull oil temps from, i would think the tapless method at the galley end where the pressure sender sits wouldn't be accurate maybe i am wrong. waymotorworks what kind of success have you had using this point for oil temp.
the filter cap does seems to be the easy target point. i dont care for the drain plug option, i think if i go for the pan i will weld a bung specifically for the sender.
i was thinking to directly tap into the oil filter housing itself or possibly a sandwich plate between the filter housing and the heat exchanger.
Kimolaoha
Jul 5, 2023 01:04 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Lex2008
Aug 16, 2015 08:33 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
