Drivetrain pulley change
Old May 21, 2004 | 04:58 PM
dennisyvonne's Avatar
dennisyvonne
Have an alta 15% and want to change to an alta 19%. Can this be done without lifting the engine. Have e-mailed Alta and Sawyer and don't get any response.
Dennis
Old May 21, 2004 | 05:02 PM
dennisyvonne
sorry "Sayther" Got it right when I e-mailed them hehe.
Dennis
Old May 21, 2004 | 05:15 PM
sfjames2's Avatar
sfjames2
whats up Dennis, how does it look down there? I think you do have to lift the engine, but removing and replacing the pulley should be easier. I dont have a pulley yet, but have read all about the removal and install and will eventually get the Alta myself. Good luck! :smile:
Old May 21, 2004 | 05:54 PM
MiniPilo's Avatar
MiniPilo
>>Dennis
I replaced mine the other day to another brand from alta. I did this with out lifting the engine. You just need the tension remover tool and some patience. A long stick with a magnet is a life saver
Old May 21, 2004 | 06:46 PM
2Cool's Avatar
2Cool
Its doable without lifting the engine. Use the tensioner tool, along with a screwdriver to wedge it open so you can get your hands down to work on the pulley. Its tedious and takes a lot of allen wrench work, but easier than the initial swap.
Also, to work the belt back on its easiest to remove the plastic skid plate under the chin and work from below.
Old May 22, 2004 | 07:16 AM
Bisch's Avatar
Bisch
Small fingers and a LOT of patience is needed, but you don't need to lift the motor. As 2cool said, do the belt work from below.
Terry Sayther sells the Goodyear GatorGrip belt. I don't know the part number, and I cannot read it any more.....but it is a kickass belt. Get it. I assume you are going to 19%?
Old May 26, 2004 | 11:54 AM
Eags's Avatar
Eags
Sorry that you didn't get a reply, please, please please try again... :smile:
My email address is
eags@terrysaytherauto.com
or
bryaneagle@hotmail.com
We have these belts in stock.
thanks,
Bryan Eagle
Terry Sayther Minimotive
Austin, TX
www.minimotive.com
cw40342
Oct 6, 2015 05:07 PM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
azntaiji
Aug 13, 2015 03:24 PM
