Drivetrain Alta intake sounds like an open faucet at idle...
Old May 16, 2004 | 01:45 PM
ZAMIRZ's Avatar
ZAMIRZ
Anybody else's Alta make a very loud hissing sound like a faucet turned on, only louder? Reason I ask is because I believe my intake is making this hissing sound (goes away when I give it a quick burst of throttle or get in the boost) and wanted to see if you all have this as well since I've been searching for a loose vacuum hose for a couple weeks now that I thought was making this sound.
Old May 16, 2004 | 01:58 PM
Bisch's Avatar
Bisch
Well, what the hell are you doing at idle?!?!?! STEP ON IT!
Old May 16, 2004 | 02:39 PM
jlm's Avatar
jlm
you might check the bypasss hose vetween the bypass valve, (located on the snoot @ the intercooler exit) and connected to the blower intake.
Old May 16, 2004 | 02:45 PM
ZAMIRZ's Avatar
ZAMIRZ
jlm, my bypass valve is disconnected. I totally forgot about it, I'll hook it back up and see if that's the culprit.
Old May 20, 2004 | 04:13 AM
JBOO's Avatar
JBOO
So did that fix your problem?
AWOL
Mar 28, 2016 10:51 AM
Mib4840
Oct 13, 2015 10:10 AM
stierzy34
Sep 15, 2015 04:40 PM
jrezzo
Aug 9, 2015 10:32 PM
