Drivetrain skid plat
Old May 14, 2004 | 03:48 PM
miniraider's Avatar
miniraider
has any body instaled one of these . any problems with oil changes or any thing else? thinking about geting one.
Old May 14, 2004 | 04:48 PM
cdconsor's Avatar
cdconsor
I've got one that I have never used (wanna buy it?). The reason being that I found it difficult to install with the extra bracket that comes with the aero kit. with the regular bumper it should be easy to install and remove (for oil changes).
Chuck
Old May 15, 2004 | 10:38 AM
JCIP's Avatar
JCIP
The Skidplate was my first mod. I got some use out of it less than a week after the install, well worth it in my opinion. I believe Moss Motors is having a sale on them right now, you might want to check it out. These are not full out rally type, more for street curbs, potholes, etc. The mounting is pretty easy, using the fastners and mounting points already in place. Again, not a pro-rally set-up, but I am glad I have it for the incidental less than perfect road.
Old May 15, 2004 | 11:07 AM
Bisch's Avatar
Bisch
If you rally or live on a dirt road it might be worth installing. Otherwise, it is just a quick way to ADD 30 pounds to the car. If you install it, use antisieze on the fasteners. It will save the mechanic a headache.
Old May 15, 2004 | 11:14 AM
dave's Avatar
dave
pug poo picker-upper
My install pics:
Interior and Exterior Mods :: Moss MINI Skid Plate Install (many pictures)
Old May 15, 2004 | 05:54 PM
jmoser's Avatar
jmoser
I got an engine oil drain valve with nipple, so I can attach a hose and drain my oil, saving the need to remove the skid plate.
I live on a dirt road and really need it....didn't want to make servicing more difficult...
here's the link for the drain valve--there's previous threads about them, but I'll just say it is well made and will NOT open independently....
http://www.fumotovalve.com/about.cfm
Old May 17, 2004 | 11:59 AM
miniraider's Avatar
miniraider
thanks guys i did see the deal @ moss mini it is prety good.......
i order it .........thanks.......
Old May 17, 2004 | 07:23 PM
GRENDEL's Avatar
GRENDEL
I wouldn't do it if you plan on "tracking" your car. When we were on the track in Neveda the only two cars to overheat had the skid plate. Plus I have heard of this happening to others.
Old May 17, 2004 | 11:15 PM
maxmini's Avatar
maxmini
Tracking the car is exactly the reason I WOULD put one on. I've exceded the laws of physics 3 times where the skid plate kept a off road excursion only embarassing and not expensive. I have the moss plate and have done over 30 k miles on it and I live in sunny So Cal which has been known to get warm on occaision. As for overehating at the track there are things you can do to help prevent that.
Randy
Team M7
Old May 17, 2004 | 11:40 PM
XAlfa's Avatar
XAlfa
Presence of a skid plate does appear to be a strong predictor of steering pump overheating and failure.
Old May 17, 2004 | 11:50 PM
maxmini's Avatar
maxmini
I had one rather agressive cyn run where the steering did get stiff after about 45 min of hard driving. I waited about 5 min and everything was back to normal. There may be a link but the added protection is still worth it in my opinion.
Suspension Products
Sep 2, 2015 10:32 AM
tag1260
Aug 19, 2015 06:18 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
