Drivetrain DIY One Ball and Big Tips Mod
Old Aug 31, 2013 | 02:49 PM
c w's Avatar
c w
I have just done a one ball mod and big tips for a mate who wanted to do his first mod on his cooper s
I will tell the short version story and show some pics on how we did this mod to make it very easy for people to do this mod
If you are doing this at home you will need
cutting tools (for cutting exhaust)
welder for welding
jack stands or means of getting car up high to do job
general tools
Parts needed
1.. 2.1/4 90degree mandrel bent pipe (perched from exhaust shop) $25.00
2.. 2 x 3inch od x 5inchs long pipe that has bee coned down at one end to 2 inch (exhaust shop did the taper down and supplied the pipe) $20.00
3.. black heat proof paint $10.00
If you don't do this at home DIY get the above exhaust parts first and take it to a exhaust shop and get them to do it ( I asked a exhaust guy I know how much he would charge if parts were supplied and said $80.00) or maybe $150.00 to do the whole job
ONE BALL MOD
So this is what we did
One Ball mod
Removed the rear muffler the one that the 2 x exhaust pipes run into the pipe from the front of the engine and crosses over to the outlet muffler
Cut and fit 90 degree pip to suit then weld ..your one ball mod is done
EXHAUST TIPS
Big Stealth exhaust tips
Remove chrome std exhaust tips by taking the little allen key screw out that locks it to exhaust pipe
Cut exhaust tips of just pass the flat steel pipe support
align 3inch tailpipes/tips then tack weld into the right spot then weld the inside of the tips so you cant see through ..your stealth tips are done
This DIY mod cost us $55.00
Good luck and hope this helps
Attached Thumbnails DIY One Ball and Big Tips Mod-exhaust-tip-001.jpg   DIY One Ball and Big Tips Mod-jade-and-mini-021.jpg   DIY One Ball and Big Tips Mod-jade-and-mini-026.jpg
Old Aug 31, 2013 | 02:57 PM
c w's Avatar
c w
Few more pics
Note... we still have to adjust the exhaust to the right a little in these pictures (easy job )
Attached Thumbnails DIY One Ball and Big Tips Mod-jade-and-mini-018.jpg   DIY One Ball and Big Tips Mod-jade-and-mini-019.jpg   DIY One Ball and Big Tips Mod-jade-and-mini-027.jpg
Old Aug 31, 2013 | 03:26 PM
JoeGravelle's Avatar
JoeGravelle
Very nice wire up, but for those of us without a welder I believe using pipe clamps works out
patsum
26
May 29, 2021 06:29 PM
larryd96
11
Sep 8, 2015 05:01 AM
Sep 4, 2015 09:10 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
