Quote:
I can get behind this!Originally Posted by E34M5
get other mods, then RPM tune. Downpipe/exhaust upgrade, JCW turbo, aftermarket intercooler, replace high pressure boost tubes with aftermarket to remove mufflers, one beside the ds rad, the other one mounted at the rear of the engine going into the firewall. Then your in business!!!!
Also even with the pedal remapped with my tune, I still use the sprint booster along with it. Another thing to consider that is cheap and easy is to add the lower motor mount (torque arm) insert. This significantly stiffens things up, helps get the power to wheels faster, and best of all (for me) significantly reduces the “squishiness” when taking off from a dead stop. Next would probably be the flywheel, but be aware of what was said about doing it up above.
Any videos with use? I'm curious how response and drivability looks like with the SprintBooster and your 40mm JMTC turbo. I run a 43mm, but I'm considering going down to a low trim 40mm compressor.
Originally Posted by MrGrumpy
I can get behind this!Also even with the pedal remapped with my tune, I still use the sprint booster along with it. Another thing to consider that is cheap and easy is to add the lower motor mount (torque arm) insert. This significantly stiffens things up, helps get the power to wheels faster, and best of all (for me) significantly reduces the “squishiness” when taking off from a dead stop. Next would probably be the flywheel, but be aware of what was said about doing it up above.
Double clutching LOL
how about an aftermarket throttle body for N18?
