Drivetrain Boost reading poll for you guys/gals with gauge
Hello All,
I have 2002 MCS with Alta 15% pulley K&N intake and Stebro exhaust. My Autometer gauge usually hits 15 psi at full throttle. Last week I did the VGS mod and now I am hitting 16 PSI.
I am not sure if I had a leak in the system or maybe the VGS is keeping the bypass valve closed better. I am going to take the bypass valve out and see if it is sitting properly.
Alec
Alec
JCW, 19%, Milltek header, straight through resonator resplacement, Alta Intake; Using Autometer electronic gauge w/ peak hold 19.5 lbs. measured at the rear end in intake plenum. (at approximately 6200 rpm)
-Boris
Car being auctioned on Ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4543773082
-Boris
tapping into the boost line
Found this string of posts interesting as I have been trying to add a guage myself.
Comment -
I started by purchasing the autometer lite series and have returned 2 of them. The first one - needle moved when I tightened the brass fittings and the second one was not at zero when it arrived! There have been other posts talking about buying a quality guage and based on my experience so far with autometer, I have opted for another brand for round 3.
Question - There is another post showing the boost/vaccum line which one needs to tap into which is on the left side of the intercooler below the aluminum ducting that takes air from the cooler to the supercharger. IS THERE AN ALTERNATIVE? because I can't reach it and it appears that I have to dismantle a good bit to reach it.
would appreciate any help in this matter that you can give.
Comment -
u may need some good long nose pliers..but being as i did the VGS mod it was pretty easy as i made a complete new vac line from inlet-fuel valve-boost valve-boost gauge...heres a pic of the nipple with a complete new hose attatched...yours will have a thin black pipe with a grey rubber nipple attatched to the end
I previously posted results with the 15% pulley plus other mods. The 2003 MCS now has a 19% Alta pulley, 380cc JCW injectors, Pipercross Viper CAI, 66-to-62 TB, ported/polished supercharger, port-match intake manifold, ported/polished head, Schrick camshaft, GRS intercooler, MM/Comptech header and Miltek exhaust. Maximum boost at WOT in 2nd gear was 17+ % as measured by a Defi electronic boost gauge. Dyno testing will be fairly soon...
Was 18psi, now 19psi at redline. See mods below.
Got an additional 1lb after I took off the gatorback belt (the one with the crosscut grooves) and installed a new NAPA belt.
Expected a loss with the GRS IC since it has more voluem, but didn't see a gain or loss. I'm happy to see my boost up considering the header and Borla Race exhaust. I live at about 100ft above sealevel.
I think M7 sums it up
When I decided to add a boost guage, I bought one from a very popular manufacturer which many here use. I don't care to bash the manufacturer but when I connected the brass hardware the needle moved
and stuck showing boost. So I sent it back to Summitracing who as a vendor is first rate
and they sent me another one no questions asked. On the second guage, the needle was not in the zero "box"
(zero is not a hash mark but a box - implying that zero is in this "area"). It dawned on me that if zero is a "an area" then how accurate can the boost reading actually be?
SO, I sent this one back
and decided to try a different manufactuer.
While, I'm not a professional driver where my life may depend on this information - it goes to the other recent post discussing paying for things that actually work or deliver what is promised.
Hopefully this 3rd guage will be a charm.
and decided to try a different manufactuer.While, I'm not a professional driver where my life may depend on this information - it goes to the other recent post discussing paying for things that actually work or deliver what is promised.
No guage yet....
but a lot of the variations in posted numbers could be due to by-pass valves. If your car is one of the lower boost cars, check that out and post what you find.
Matt
Matt
2003 MCS
15% SC pulley
4% Crank
Alta cold air intake and hose
Stock software
AFC select
Alta TMIC
Autometer Mechanical Boost Gauge
Best I've seen is 16.5 at stock redline. I'm in Dallas which I think is a couple of hundred feet.
15% SC pulley
4% Crank
Stock software
AFC select
Alta TMIC
molala
Oct 2, 2015 01:53 PM
