Drivetrain I flunked math...now I need help!
Old Mar 12, 2004 | 06:19 PM
MSFITOY's Avatar
MSFITOY
What a pain in the A$$ to get these Hsport camber links on :smile:
_________________
Old Mar 12, 2004 | 06:35 PM
Ryephile's Avatar
Ryephile
sin^-1 (delta the distances top of wheel to bottom of wheel)/(diameter of wheel. Not advertised wheel diameter, but the actual wheel lip diameter. Usualy advertised in inches plus one inch (guesstimate). same units, otherwise you cannot divide the two, duh
Side A; 18mm delta, 18 wheel lip diameter
sin^-1 (0.7087/18) = 2.26 degrees or -2.3 degrees of camber
Side B; 28mm delta, 18 wheel lip diameter
sin^-1 (1.104/18) = 3.51 degrees or -3.5 degrees of camber
Geez Sid, did you not pay attention when you were installing the links? One side is close to stock, but the other is turned out 1.5 turns!
With the H-Sport (Promini, same thing), usually 1 full turn = 1 degree. With big rear swaybar, you want about -1.5 degrees
Basically, you want about 0.5" or 12mm delta from top of rim to bottom of rim to get -1.5 degrees of camber.
You're welcome,
Ryan
_________________
Old Mar 13, 2004 | 06:45 AM
MSFITOY's Avatar
MSFITOY
Sorry Ryan...my cell ran outta battery :evil:
Thanks for the math lesson I spent my time in math classes drawing cars
Old Mar 13, 2004 | 08:28 AM
Ryephile's Avatar
Ryephile
No problem Sid - let me know how it goes
Old Mar 13, 2004 | 12:55 PM
MSFITOY's Avatar
MSFITOY
Got it. Went out and got a 1-1/8" wrench and ended up with a 15mm delta for both wheels at the top. What do you calculate the camber to be? You mentioned 12mm for -1.5 so I should be pretty close?
Thanks and leave the drawing to me
_________________
Old Mar 13, 2004 | 01:19 PM
Bisch's Avatar
Bisch
Ryan,
Your intelligence makes my head hurt!
Old Mar 13, 2004 | 01:21 PM
Deli's Avatar
Deli
Ryan:
I was astounded that Trippy didn't beat you to the punch in responding to this one! He must be our motoring...
Old Mar 14, 2004 | 09:20 AM
Ryephile's Avatar
Ryephile
15mm delta equates to -1.9 degrees of camber. That'll work
---> [Hands Bisch some aspirin]
Motor-On!
Ryan
whovous
DC Metro MINIs (Archive)
12
Sep 7, 2005 05:41 AM
Chief_Charlie
Aug 21, 2003 01:21 PM
