Drivetrain shift knob and B&M short shifter...
Old May 9, 2012 | 03:56 AM
coolewong's Avatar
coolewong
shift **** and B&M short shifter...
Hi guys, I just bought a 04 r53 as my DD
The last owner installed a B&M short shifter and an aftermarket shift **** on it.
After doing some research, I found that the thread size of the short shifter is M12x1.25.
Hence, I ordered a BLOX ball-shaped weighted ****
However, when I was trying to remove the old shift ****, a problem appeared...
I CANNOT remove it!
I rotated it anti-clock wise, and after giving some power it loosened and can freely rotate it.
Then I thought,"Great! Time to take it out!"
...But it won't.
I continue to rotate it counter-clock wise... for at least 30 mins.
Yet I didn't really see any differences... Same height.
So here comes the question: Should I just pull it off like the oem one?
Old May 9, 2012 | 06:39 AM
Evasive's Avatar
Evasive
Here are instructions on how B&M was installed. I'm thinking that you just pop it off as well.
http://www.pelicanparts.com/techarti..._Shift_Kit.htm
Old May 9, 2012 | 11:51 AM
coolewong's Avatar
coolewong
I tried really hard to pull it off but still couldn't.... and tried to rotate it but still not coming out anyone using the same short shifter?
Old May 9, 2012 | 12:05 PM
Evasive's Avatar
Evasive
Did you try rotating it while pulling up at the same time?
The tip is threaded and not notched, so it should just spin off.
Old May 9, 2012 | 04:11 PM
Professor's Avatar
Professor
I had to destroy my OEM **** to get it off the B&M. pissed me off enough to remove the B&M.
Old May 10, 2012 | 05:20 AM
coolewong's Avatar
coolewong
Can't spin it off...-_- any other ways to take the **** off?
Old May 10, 2012 | 06:53 AM
Braminator's Avatar
Braminator
Make sure on the aftermarket shift **** there are no set screws. They are usually under a trim ring on the bottom of the shift ****.
Old May 10, 2012 | 09:56 PM
ERIK06MCS's Avatar
ERIK06MCS
If there is no set screw and the **** does not pull off then I'm thinking the threads were destroyed on install and your probably twisting the thing hopeless forevermore.
I can tell you from lots of experience with other cars that sometimes you have to PULL like crazy to get a pressed **** off. And don't hit yourself in the face when it finally pops because many of people have done that.
Otherwise I've got no experience with B&M shifters or whatever aftermarket **** you have on there. Good luck!
Old May 11, 2012 | 05:05 AM
coolewong's Avatar
coolewong
Sadly I don't think I can destroy the shift **** on there now.. It's made of hard wood lol
So are we *SUPPOSE* to spin it off?
Old May 11, 2012 | 07:02 AM
ERIK06MCS's Avatar
ERIK06MCS
If you look at the link Evasive posted then you can see by the picture that the lever itself has threads on the end. However, you can mount the OEM **** onto the B&M lever too by pressing it down (because the OE ***** are not threaded).
Here's another link: http://www.paperlessusa.com/MINI/MIN...rtshiftkit.pdf
What it comes down to then is not the lever but whatever **** you have on there. It seems this lever will accept both press fit and screwed on type applications. If unscrewing isn't getting you anywhere then I'd have to believe you have a press fit ****. If the **** wasn't from B&M then perhaps it was threaded by the threads are stripped in which case you might have to get out a dremel and just cut the wood off.
Grizld700
Dec 30, 2015 10:47 AM
LAcooper
Sep 22, 2015 10:03 PM
Mynewt
Sep 14, 2015 11:55 AM
nayr924
Sep 8, 2015 02:41 PM
SneedSpeed
Sep 2, 2015 05:34 AM
