Drivetrain all wheel drive/ engine swap!
Old Mar 23, 2012 | 08:41 PM
crazydrumer911's Avatar
crazydrumer911
so i want to do an all wheel drive setup due to i want to rip other cars to shreds, and i want to due an engine swap preferably with a turbo any suggestions or help is what im looking for if ur against it don't post anything i have all the time and money and i want to make my r53 a monster
Old Mar 24, 2012 | 12:06 AM
[insert name here]'s Avatar
[insert name here]
Sounds fun! Personally, I would just get a subaru if you want AWD. You might want to actually look into their set up as well, since they are either FWD or AWD models. It will be more like the setup you will need to convert yours from a FWD to the AWD. Don't know though since they use the horizontally opposed engines.
This is the most extreme conversion I know of:
You might be able to swap the system from a subaru, their models are turbo charged. Going to need a lot of custom work though, and a lot of funds.
If you have that amount to spend, it is your money so it is up to you.
You might want to get a Nissan GTR though, just saying
Note: To see more of the Mini above, google search Hemi Mini, there is even a youtube vid.
Old Mar 24, 2012 | 08:30 AM
ZippyNH's Avatar
ZippyNH
R53 was never set up for this....
Awd...
Outside of making it a full on rally car...don't think it gonna work without major work and fabrication ...think new floor for a drivshft, moved fuel tank and new floor to fit a rear diff...if you can get a transfer case...and the hp...
would love to see it done for less than $40,000.
Old Mar 24, 2012 | 08:47 AM
ZippyNH's Avatar
ZippyNH
In a nutshell, the end result would be a custom car with a mini body...but no real mini left.
Good luck, have at it. If go have the $$ to spend on parts, labour, and research, great, folks need jobs!!
Old Mar 24, 2012 | 09:44 AM
JPMM's Avatar
JPMM
get a wrecked all4 Cman for a donor car
Old Mar 24, 2012 | 10:19 AM
DneprDave's Avatar
DneprDave
+1
Dave
Old Mar 24, 2012 | 02:55 PM
crazydrumer911
haha i have 2 gtr's and a v10 r8 so money isnt the isue i just want to make my current r53 nuts i heard that a srt4 swap would work but im not sure if its true
Old Mar 24, 2012 | 03:46 PM
[insert name here]
Wanna donate a GTR to me since you have two?
(one of my dream cars)
Old Mar 24, 2012 | 04:02 PM
UKSUV's Avatar
UKSUV
Who are you...Robert Himler?
Old Mar 24, 2012 | 04:13 PM
MINIdave's Avatar
MINIdave
You have the same problems to overcome as with every engine swap into a MINI, space and the computer interface. The engine compartment in a MINI is tiny, it's tight with the MINI engine in there, let alone anything bigger. Even the Countryman stuff won't fit, which is why there's a Countryman. (it's physically a lot bigger than a MINI hatch.
If I were going to do this I think I would go with Honda CRV stuff, there are a gazillion Honda tuner shops out there and there is every upgrade in the world available, so you could get huge HP and the CRV already is a 4wd system, all you'd have to do is make it fit - but that's the hard part! Use all of the ecm from the Honda or an aftermarket setup.....
The Neon wasn't AWD, was it?
You might also consider doing a "Twini", adding a engine in the rear to get AWD and lot's of HP.
If you're not doing the work yourself, you could spend as much as that R8 doing this, just FYI....
Old Mar 24, 2012 | 04:18 PM
Professor's Avatar
Professor
Getrag developed an all wheel drive setup for the R53 and presented it to MINI. They did not go for it sadly.
Old Mar 24, 2012 | 04:21 PM
Professor's Avatar
Professor
Only pic I can find. Notice the drive shaft
Old Mar 24, 2012 | 06:11 PM
crazydrumer911
for mini dave. i would be doing the work myself the only problems that i would run into is the drive shaft problem. if its to hard to make it and awd is it posible to do a rwd setup
Old Mar 24, 2012 | 06:13 PM
crazydrumer911
o btw gtr's not for sale sry. ones my project other is daily
Old Mar 24, 2012 | 06:37 PM
MINIdave's Avatar
MINIdave
Well, it's possible to do anything given enough time, engineering expertise and money, but are you talking about making a FWD into a RWD? Cause I can't think of any way to successfully do that, save doing what they did with that MINI racecar. For that one they basically used the MINI body over a tube frame racecar that used a BMW drivetrain, front engine, rear wheel drive.
Or are you thinking about making the MINI rear engine and RWD?
It all comes down to how crazy you want to get......
Old Mar 24, 2012 | 07:08 PM
crazydrumer911
i would perfer to make it just rwd if its to hard to convert to awd
Old Mar 24, 2012 | 07:24 PM
Dex05S's Avatar
Dex05S
I don't know how far along they are, but Think Mini is working on an AWD R53. The donor parts are VAG, including a Quattro trans. They also worked out the computers from the Mini and VAG communicating to each other.
Old Mar 25, 2012 | 01:43 PM
SpiderKnight's Avatar
SpiderKnight
I think the easiest way would be two electric hub motors in the back, some powerful batteries, and a slick controller.
Old Mar 27, 2012 | 02:08 PM
astroBlackMetallic_Mini's Avatar
Old Mar 27, 2012 | 08:59 PM
crazydrumer911
gota love the haters lmao! ur a joke
Old Mar 28, 2012 | 04:21 AM
soccerbummer1104's Avatar
soccerbummer1104
his comment gave me some inspiration. Contact Prodrive. They are the people who build the ralley spec countrymans. They may be able to source the parts and do most of the custom work for ya.
Old Dec 5, 2012 | 04:13 PM
Fatandre's Avatar
Fatandre
guess the dream is dead
Old Dec 5, 2012 | 04:37 PM
Boosted_Mini's Avatar
Boosted_Mini
Originally Posted by astroBlackMetallic_Mini
im sorry, i know this is an old thread, but, dude, really?
1. why would you want to engine swap an R53? why wouldnt you just GET a turbo'd mini?
2. if you have 2! GTR's, wtf are you even DOING with a Mini?
3. im sorry, but its fairly outrageous of you to Flaunt your (supposed) "unlimited cash flow" by making these ridiculous comments about modding a car.
finally, if you wanna do 4wd, get a countryman, those are about as close to 4wd as possible, get a turbo version, and beef that up...
The R53 is in every way you can imagine better than the R56 engine. I dont know why you wouldnt ever want to use that engine especially if you want to gain hp.
Old Dec 5, 2012 | 04:47 PM
ColinGreene's Avatar
ColinGreene
Says the dude who owns a R56.
Old Dec 5, 2012 | 06:00 PM
Boosted_Mini
I like to learn the hard way what can i say.
