Drivetrain looking to get more power for my MINI any advice?
Old Mar 12, 2012 | 09:28 PM
delgadilloj49's Avatar
delgadilloj49
things i already got on my MINI:
alta cai
msd ignition
alta pulley and crank pulley
have obx headers but still havent installed them but im looking for the other good things to give it more power. what do you guys think of a camshaft or intake manifold think that would help?
Old Mar 12, 2012 | 11:02 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
alta cai
msd ignition
really depends on your budget. Camshaft won't be worth that much for power, ported and polished manifold and head would be good but costly with installation unless you do it yourself.
Best next thing is lighter exhaust and Revolution Motorwerks or Mynes ECU map for more power given you have alta reduction pulley already.
The MINI doesn't really need that much additional power, about 200-230 hp is enough. What it needs is good suspension that is adjustable and aggresive alignment with lighter wheels, firmer brake pads and sticky Extreme Summer tires.
Old Mar 13, 2012 | 01:09 AM
BlwnAway's Avatar
BlwnAway
I agree, unless you want to start spending a considerable amount & go the BVH route, install your header, custom tune & 380cc injectors, then start stripping weight.
It's amazing what loosing a couple of hundred pounds will make the car feel like.
Old Mar 14, 2012 | 07:20 PM
delgadilloj49
@minihune can i get the websites or links where they sell those ECU's?
Old Mar 14, 2012 | 07:25 PM
delgadilloj49
@blwnaway think that would be a good upgrade with what i barely have on my MINI to throw some injectors?.
Old Mar 14, 2012 | 10:50 PM
minihune's Avatar
minihune
http://www.waymotorworks.com/bytetro...uning-kit.html
$750 for full access to the software. You can buy dyno time and get a tuner to install your custom MAP. Do this only after you do all the hardware upgrades for power.
Or check where Jan is doing ECU map installs
http://www.revolutionmotorworks.com/...3&product_id=5
$350 per tune from Revolution Motor Works
He travels around the country doing tuning parties
Old Mar 15, 2012 | 07:24 AM
MiniMacPR's Avatar
MiniMacPR
IMHO, I wouldn't do anything with the intake manifold, it's fine as it is and any gains are really minimal. With what you have, the big items left before going with a Big Valve Head is a cam with appropriate injectors and a competent tuner to put it all together.
If you are on a budget right now I would just go ahead and install your header and get a tune, which is really the key here. A competent tune is the big gain item left right now before going BVH or any other more radical way (charger change for example).
Colt45Magnus
Jul 14, 2019 06:18 PM
mdorn98
Aug 11, 2015 08:49 AM
MiniJess
Aug 10, 2015 09:51 PM
USA-RET
Aug 6, 2015 09:22 PM
