Drivetrain 19% pulley happy or not
Hook....line.....and sinker.
Thanks.
Oh, another question. Can't I just wrap a shorter belt right around the supercharger shaft and not even bother with a pulley? Quit *****-footing around and go for the 100% reduction!
Thanks.
>>Please indicate if you have one and if you would do it again. Please stick to subject.
Heck YES I would do it again. Zero problems. AWESOME POWER. On a scale of one to ten I would rate it a 12. Even if a 19% pulley install costs $5,000 dollars (of course it doesn't) it would STILL be worth EVERY PENNY.
I hope that answers your question.
RaceCarDriver
RaceCarDriver
RandyBMC wrote on Feb 20, 2004:
Once again, do you have any A/F charts to back up what you are saying about the A/F? Have you heard any other reports of failure with the 535 belt? Any pics of your failure? What brand of 19% pulley was on your car when you had the seal failure?
Actually, I have had better luck with the 060539. With the 535, there is a bit too much tension on the belt, and it has failed on me at the track and on the street (2 belts) back when we were still testing the pullies. During this latest round of 19% testing with the Alta unit, I have used the 539, and haven't lost one yet.
You may want to use that one on future installs Tres - it is also available over the counter at NAPA .
Here is an issue with the intake temps - the ECU has a protection that enrichess the mixture if the intake temp exceeds I believe 78C. That means your A/F ratio goes to hell, and you lose power. An intercooler would be required to maintain your A/F ratio. I think the 15% will end up being a bit more efficient at the higher ambient temps. We'll have to wait for warmer weather and do some testing. Don't run out and buy an intercooler yet, because we don't know what the temps will look like just yet. More testing, woohoo!
Hope that helps,
Randy
Hope that helps,
Randy
elverado
Jan 18, 2022 02:51 AM
bADbOYbECK
41
Oct 16, 2015 12:39 PM
Was it a drive-by?
