Drivetrain REAR Wheel Bearings
Old Dec 1, 2011 | 08:30 AM
abjb's Avatar
abjb
REAR Wheel Bearings
OoPpSs wrong sub forum.
I'm going to repost in "Stock Problems/Issues"
We tow our 05 MCSa behind a motorhome, front wheels on a tow dolly.
Which puts more pressure AND miles on the rear bearings.
Are the rear wheel bearings sealed or can they be serviced?
I would MUCH rather do a little preventative maintenance than call a tow truck in the middle of Wyoming or Arizona, etc.
ab
Old Dec 1, 2011 | 03:58 PM
KC Jr 54's Avatar
KC Jr 54
They are a sealed unit and are replaced as such. There really is zero maintence that can be done to them sadly, but if you can do a rear brake job, then you can easily replace them if need be.
http://www.minicarparts.net/Parts/33....cfm?ref=nxtfb
Backside of wheel bearing/hub assembly: (you can actually see the heat marks on the hub face from when it was pressed together.)
wkp1219
Nov 13, 2015 07:52 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
