Drivetrain M7............New front control arm system II
Old Feb 11, 2004 | 07:35 PM
M7's Avatar
M7
More cool stuff from M7......And you asked for it
To satisfy the masses.. We decided to make a control arm system that would retain the stock arms but give you
better control of the suspension movements. The stock arm has a hexagonal shaft that needs to be converted to a
round shaft. The steel shaft fits snugly over the stock part, and the threaded hole in the part locks the two pieces
together with a countersunk screw. For superior lubrication we are using a Teflon impregnation of the part.
Delrin and self lube bronze bushing is used in the main body bushing, replacing the squishy imprecise
stock unit for better control of your camber, caster, toe and better up and down movement (arc).
This uppgrade is taking the the suspension to the next level of refinement.......Enjoy
Price: $ 249.00
For purchase please call...
peter horvath
562-712-3270
_________________
Lightest and fastest in SoCal
Old Feb 12, 2004 | 06:22 AM
Trippy's Avatar
Trippy
Now you're talking!
Nice, precise application of changing just the problem bits.
I do hear that it is really hard to replace this particular bushing though.
Should I try it myself, or take it to the shop?
Old Feb 12, 2004 | 06:52 AM
jlm's Avatar
jlm
not to crap on your parade, but Powerflex makes a similar product for considerably less $. A tough polyurethane outer and a nylon inner.
http://www.promini.com/images/produc...ControlArm.jpg
_________________
""the onus of proof is on he who asserts the positive."
Old Feb 12, 2004 | 07:01 AM
Ryephile's Avatar
Ryephile
John - you're crapping in the wrong area.
Delrin/bronze bushings are superior to polyurethane when you're looking minimal excursion and maximum stability at the cost of NVH, so the price point is appropriate for the major-enthusiast/Racer crowd. Nylon is more compressible and less self-lubricating than Delrin, and Delrin's cost is proportionally more because of it's more complex chemical structure.
Nice product, Peter! Any toying with offset bushings?
Ryan
Old Feb 12, 2004 | 07:44 AM
macncheese's Avatar
macncheese
>>Ryan
Eh, im with john on this one. If you're ballsy enough to go to delrin, you should be ballsy enough to go for tubular arms. This is an interesting solution but it's still going to ride too harshly for the street in my opinion.
Cheese
Old Feb 12, 2004 | 08:55 AM
jlm's Avatar
jlm
one shortcoming of the stock bushing is that is uses the compliance of a rubber center (vulcanized to a steel shell) to mangage the rotation of the control arm (normal suspension compression/extension) and the off-axis loading (due to braking/acceleration/fore-and-aft forces)
what the aftermarket solutions both do is substitue a rotation bushing to manage the rotation action (suspension movement). The Powerflex then uses the much stiffer than rubber but still compliant polyurethane for the off axis load control, while the M7 uses a nil compliance delrin.
M7 would be great for the track, I'm sure, but for the street might seem a bit rough
Old Feb 12, 2004 | 04:54 PM
M7's Avatar
M7
yes this is a shop job, unless your mechanicaly skilled and know your way around the MIni
The Poly bushings are ok but they still give, and to top it of sqeek. The m7 system utilizes the Delrin outer shell
with a self lubricating bronze bushing as the inner part, many people has told me that it's smother over bumps and
uneven surfaces as there is basicaly zero resistance in the up/down movement of the arm.
peter
Old Feb 12, 2004 | 05:42 PM
Ryephile's Avatar
Ryephile
That's right Peter, the control arm articulation will have less resistance than stock, due to the bushing design, however NVH will be dramatically increased due to material choice. Like I said in my above post - this is best for the track, or very smooth roads (like The Dragon!)
Cheese - Wimp! In terms of value, doing just the bushings is the majority of the improvement in terms of steering and suspension resolution. Installing lighter/stronger control arms is just icing on the cake. If you want handling precision, you'll have to pay the price for it (NVH).
Old Feb 12, 2004 | 08:00 PM
macncheese's Avatar
macncheese
Im a wuss alright. I have enough NVH problems with this car :smile: BTW, NVH can/does effect reliability, especially in critical places... Track junkies enjoy, this isn't for me :smile:
Cheese
Old Feb 12, 2004 | 08:34 PM
BlueMCS's Avatar
BlueMCS
Sorry Surfers, those bearings wouldn't last a week on our Eastern roads that eat alloy wheels for lunch. They wouldn't last jlm a day where he hangs out.
I'm looking forward to doing the poly bushings when I do the front bar.
So, what r u running for a front bar Peter? I'm taking a close look at Ireland's offering (2b).
Old Feb 12, 2004 | 08:45 PM
M7's Avatar
M7
Honestly guy's......
It's not bad at all (NVH) your exhaust or CAI makes more of a racket and for vibration and harshness, low profile
tires is way worse.......Honestly
The most important thing is....your car will perform better with more precission and feel....and that's what counts.
peter
_________________
Old Feb 12, 2004 | 09:49 PM
M7's Avatar
M7
H-sport all the way
W0TM8
Dec 19, 2019 07:50 AM
wkp1219
Nov 13, 2015 07:52 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
