Drivetrain Godspeed TMIC
Old Jun 20, 2011 | 05:28 PM
Rose-W's Avatar
Rose-W
Godspeed TMIC
I was looking to upgrade my tmic and i stumbled upon this. I have seen tons of people put the godspeed intercoolers on dsm, rx7, civics, but has anyone heard of or tried a Top mount version on the MINI also any ideas of what to do with a diverter?
MINI COOPER S 02-06 UPGRADE BOLT ON TOP MOUNT INTERCOOLER
core length 11"
core height 8"
core thickness 2.25"
inlet / outlet size : for mini cooper only
end to end length 16"
http://www.godspeedproject.com/store...oducts_id=1503
Old Jun 20, 2011 | 05:37 PM
Rose-W's Avatar
Rose-W
Sorry i just realized i posted this in the wrong section
Old Jun 20, 2011 | 06:49 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
When it comes to our IC's, bigger is not necessarily better. And if you can't remove that plastic monstrocity of a bonnet diverter and bolt a DDM or Alta diverter to the IC, I would hold out for a good one unless you are just into the "bling" scene.
Old Jun 20, 2011 | 07:06 PM
Rose-W's Avatar
Rose-W
ya thats pretty much what i was thinking just didnt know if anyone had used one before. Would you have any suggestions to a good intercooler, im looking for around 300 hp to the crank with meth injection.
Old Jun 20, 2011 | 07:18 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
That looks cheap. The mounting tabs aren't even usable since they don't line up with where the brackets would go. This can be bad cause under load the intercooler will move with the boost and can pull the boots off.
Check out the GP intercooler, it has shown IMO to be the best.
Old Jun 21, 2011 | 01:47 PM
JumpingJackFlash's Avatar
JumpingJackFlash
+1 to GP IC.
Old Jun 21, 2011 | 04:48 PM
MrNintend0's Avatar
MrNintend0
Look at how much the rubber couplers are displaced when the godspeed IC is installed. I highly doubt that is good for the couplers, which are under stress already...
+1 for the GP IC as well, for a quick and easy installation
Old Jun 21, 2011 | 04:54 PM
Longboard110's Avatar
Longboard110
apparently you only need 3 of the 4 clamps.
Old Jun 21, 2011 | 05:13 PM
MINI33342's Avatar
MINI33342
Wow....that is a major POS LOL
Save your money and get some actual go fast parts......pulley, intake, exhaust, head, tune. The OEM IC is a very efficient design and really doesn't need to be replaced until you start upping the HP of the engine.
Old Jun 23, 2011 | 06:55 AM
banzairx7's Avatar
banzairx7
Just noticed in the install picture the intercooler is mounted 180 degrees out. It looks like the mounting tabs that they show up top would line up if the intercooler was flipped. That solves the poor mounting comments. Doesn't help with the tweaked couplers or if it even helps cool the inlet air any better though.
Winchm60
For Sale (DC Metro MINIs) (Archive)
12
Dec 20, 2008 01:08 PM
Myke@RPI
14
Jul 14, 2008 07:48 AM
draggonmann
Jul 11, 2008 09:21 PM
TampaMCS
Mar 18, 2007 07:00 PM
MSFITOY
May 16, 2006 06:40 PM
