Drivetrain Discharge and Air Charge Pipes
Old May 24, 2011 | 12:24 PM
  #26
Bigprfed22's Avatar
Bigprfed22
Makes the drive to and from work fun
Originally Posted by sLy201
Heyy find a reason and justify it with any excuse lol ... Im not taking a summer vaca coz im the new guy at work and want to make an impression so this summer its about improving my fun factor on my mimi
Old May 24, 2011 | 12:52 PM
  #27
rohicks's Avatar
rohicks
Originally Posted by Bigprfed22
You read incorrectly, there are no filters within any of the pipes. the hot side pipe as a muffle built in to the pipe to help reduce noise, the hot side has an extension to help accentuate engine noise inside the cabin. All part of acoustics tuning.
They are just pieces of pipe. buy which ever you like best, or make your own at www.siliconeintakes.com
A little correction ...
You mean the "cold side" used to have an extension to help accentuate engine noise inside the cabin.
Check this post for more information. The 2011 models do not have the cold side 'noisemaker' anymore.
https://www.northamericanmotoring.co...0-post121.html
Full Thread - https://www.northamericanmotoring.co...-revealed.html
Old May 24, 2011 | 12:56 PM
  #28
jomama's Avatar
jomama
depends on the month of build. my 2011 has it, but i'm guessing the OP's will not. i believe his car was ordered and delivered in mid april, so he must have one of the latest builds on the road.
Old Dec 25, 2014 | 09:00 PM
  #29
potterstein's Avatar
potterstein
Bit of a bump in an old thread...but has anyone actually tried this for the air charge pipe (like this one http://www.nm-eng.com/254/11/0/2444/...ipe.html#popUp[products]/1/)? I mean it looks simple enough, 2 90 degree bends and some straight pipes...but i'm probably wrong :(
Old Jan 3, 2015 | 07:53 AM
  #30
tomy's Avatar
tomy
+1000 do the pipes. From when did my own I notice faster spool. I don't have the opportunity yet to do a dyno to see if I won horsepower.
Old Aug 3, 2015 | 01:51 PM
  #31
Chrismonson's Avatar
Chrismonson
I installed the air charge pipe on my countryman s and after driving around it for sure feels like I have lost power. Any suggestions or advice? I can hear the air coming thru a lot cleaner but at higher RPM's it's not as strong.
Old Aug 3, 2015 | 02:27 PM
  #32
Grizld700's Avatar
Grizld700
Double check all your connections. Then triple check. There shouldn't be any power loss.
Old Aug 3, 2015 | 07:03 PM
  #33
dbak2005's Avatar
dbak2005
anybody use the waymotorworks noise maker delete pipe and resonator delete pipe? looks like the most bang for the buck.
Old Aug 3, 2015 | 07:49 PM
  #34
WayMotorWorks's Avatar
WayMotorWorks
Vendor
They really are. We've had great luck with them and they fit perfect. Would love to have users post more feedback.
I can tell you the noise maker delete makes a bigger difference between the two if you are planning on getting them one at a time.
Old Aug 5, 2015 | 05:03 AM
  #35
atlas8000's Avatar
atlas8000
I have the WMW noise maker delete and have been happy with it. I have noticeably better throttle response, especially in stop and go traffic. I didn't notice any change in cabin engine sounds so I have no idea what the noise maker was doing in the first place.
Install was easy and the part is very high quality, fit perfectly with the OEM pipes. Thanks to Way for suggesting it over the NM pipes as it saved me a lot of money!
Old Aug 13, 2015 | 08:53 PM
  #36
teinesina's Avatar
teinesina
Can anyone give me some tips on how to get the old one off??? I have the nm cold side pipe I want to put on but it's so damn tight in there I can't get enough leverage to even pull the old one off!
I'm frustrated that such a simple thing is so hard!
Old Aug 14, 2015 | 05:18 AM
  #37
atlas8000's Avatar
atlas8000
Originally Posted by teinesina
Can anyone give me some tips on how to get the old one off??? I have the nm cold side pipe I want to put on but it's so damn tight in there I can't get enough leverage to even pull the old one off! I'm frustrated that such a simple thing is so hard!
To get the noise maker off I used a large screwdriver to pry back the hose and then inserted a smaller screwdriver that I worked around the pipe to loosen it up. It was definitely frustrating and I skinned a few knuckles in the process but once I got the smaller screwdriver in there it came apart quickly. Good luck!
Old Aug 14, 2015 | 11:44 AM
  #38
Grizld700's Avatar
Grizld700
+1. I did mine 2 years ago and I have and '07 so that pipe was on there really good. It'll take a while.
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 7, 2015 07:51 PM
eliseo1981
Sep 4, 2015 02:33 PM
M7Speed
Sep 3, 2015 07:48 AM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
