Drivetrain Another Pulley Thread, SORRY!
Old May 19, 2011 | 05:54 PM
  #26
Crashton's Avatar
Crashton
My advice would be to get your MINI running properly & checked out before adding a pulley. At 98K it is most likely OK, but you'll want to be sure before putting more load on it. I've been running a 15% pulley for about 90K. So far so good.
Old May 20, 2011 | 08:13 AM
  #27
stt816's Avatar
stt816
it feels like just above 3k rpm is when it actually responds good to me, so have the spark plugs replaced....any other suggestions?
Old May 20, 2011 | 08:37 AM
  #28
Crashton's Avatar
Crashton
Plug wires....
Old May 20, 2011 | 12:09 PM
  #29
ZippyNH's Avatar
ZippyNH
Starting to pull good at 3000+ is pretty normal...
the airflow is cooling the ic....and the motor gets into it's tourque band...below 3000 the ta is kinda limited....a tune helps a bit..
Old May 21, 2011 | 09:04 PM
  #30
Quadrivium10's Avatar
Quadrivium10
Great post!
I've been researching the ALTA 17% reduction and 15% reduction pulley. Seems like an easy mod but knowing about the revs and ideally switching to the JCW spark plugs is a good FYI to know.
What are the "good to know" items about supercharger pulleys and "should definitely have done/upgraded" so you don't damage the car bits of info??
Thanks!
Old Jun 1, 2011 | 11:17 AM
  #31
schreiber117's Avatar
schreiber117
15% is popular, but since I don't live at red-line, I went for the 17%. it can be harmful if this is a pure track/autocross toy, but for the daily driver, with occasional run to red-line, I found it was a perfect match.
That said, it really became a huge difference after a tune...
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
The_Kid
Nov 3, 2016 06:30 PM
JaysinStrife
Jun 3, 2016 09:19 AM
M7Speed
Sep 3, 2015 07:48 AM
