Drivetrain People with engine modifications:
Old Jan 17, 2004 | 05:58 PM
Andrewsky's Avatar
Andrewsky
Have you ever had your engine overheat? How much does a performance radiator for the S cost?
Old Jan 17, 2004 | 06:09 PM
minilites's Avatar
minilites
How's it going! you may want to check out the Moss Mini web site.
http://www.mossmini.com they have a aluminum radiator,2 row core design.
price.$499.95 good luck.
Old Jan 17, 2004 | 06:14 PM
Andrewsky's Avatar
Andrewsky
That radiator is for the regular Cooper only. Thanks anyways though.:smile:
Old Jan 18, 2004 | 05:32 AM
d-mini-ero's Avatar
d-mini-ero
I have a pulley, air-intake,exhaust & an ECU remap..... and my MCS has never overheated.
As far as the performance radiator ... please visit one of our tuner sponsors and they'll be able to help you out :smile:
http://www.webbmotorsports.com/index.php is a good place to start
Peace,
D
Old Jan 18, 2004 | 07:09 AM
Jayar's Avatar
Jayar
I imagine a performance radiator would keep engine temp. down, but if your car is actually overheating, there is likely a problem other than engine mods. Coolant reservoir leaking? In other words, I wouldn't assume the car is overheating because of additional horsepower. Running a little hotter, maybe...good luck.
Old Jan 18, 2004 | 08:04 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
I've had the pulley since last February (15,000 miles ago) and haven't had any cooling problems (other than the leaky coolant tank that seems to plague all MCS). According to my digital water temp gauge, even in 100F heat and fast driving in the summer, my coolant rarely hit 215 F, and when it did, the fan kicked on and lowered temps in a jiffy.
Old Jan 18, 2004 | 11:04 AM
greatgro's Avatar
greatgro
I don't think his engine has overheated. I think he's just asking if it is a concern.
Currently running 19% pulley, intake, exhaust - no problems.
Ran above with 15% pulley during the summer. No problems.
Old Jan 18, 2004 | 11:15 AM
Antranik's Avatar
Antranik
What might be more of a concern are the oil temperatures when running this engine hard. What do you guys think?
Old Jan 18, 2004 | 01:08 PM
M7's Avatar
M7
Hey.....
I am currently testing our new oil cooler at a test lab, comparing flow, cooling and pressure drop compared
to stock unit which is terribly constrictive both in cooling and flow. I will have graphs charts and other goodies
to show by next week. The M7 unit is water cooled and will be a bolt on replacement unit, I will also have an
Accusump interface for even better oiling capacity.
peter horvath
562-712-3270
Old Jan 18, 2004 | 02:33 PM
greatgro's Avatar
greatgro
Now an oil cooler sounds like a great product. Not just for hard driving, either. The MCS runs very low oil pressure at idle and low speeds when hot. Keeping the oil cooler would be very beneficial I would think.
Old Jan 18, 2004 | 03:04 PM
jlm's Avatar
jlm
there is an optimum oii temp and synthetics are designed to run hot; does the M7 unit have the ability to maintain temp without over cooling?
Old Jan 18, 2004 | 05:58 PM
M7's Avatar
M7
I will have #'s and more info for you all within day's.
peter horvath
562-712-3270
woodstudio
Mar 15, 2020 08:28 AM
boostedhaze
Jan 2, 2018 07:26 PM
Aug 21, 2015 10:07 AM
minipopkart
Aug 13, 2015 05:22 AM
